Digital AC Swap
Old Jul 26, 2009 | 11:25 PM
saride's Avatar
saride
Digital AC Swap
Has anyone out there swaped the digital AC controls for the manual controls? Any help would be appreciated.
Old Jul 27, 2009 | 01:40 AM
FTE Trigger's Avatar
FTE Trigger
I personally haven't done it... or pondered on it.
But here is a related thread from earlier that may help.
https://www.ford-trucks.com/forums/5...trol-swap.html
This one is "backwards" from what your looking for, but it may help...
https://www.ford-trucks.com/forums/2...l-display.html
Old Jul 27, 2009 | 04:23 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
good luck
nobody has really tried it. the parts alone make the swap hideously expensive.
and then you have to replace your entire dash and the pcm...and instrument cluster. Or if you are lucky, your current cluster is good enough and you can merely re-program it and the PCM
gymbo88
2004 - 2008 F150
Jul 19, 2014 04:55 PM
Pele
Jul 6, 2014 01:32 AM
tadpole68
Nov 24, 2013 08:47 PM
Gizmo2009Ford Expedi
Dec 21, 2010 07:20 PM
drrv1
1997 - 2003 F150
Sep 12, 2003 12:16 PM
