EGR coolant bypass.
Old Jul 28, 2009 | 06:37 PM
Maxium4x4's Avatar
Maxium4x4
Originally Posted by bismic
I will say that the friend who I asked to weld the valve is worried about warping it while welding.
Mark, all you need to do is tack weld it in a few spots, not completely weld it shut. Hope that helps.
Old Jul 28, 2009 | 06:49 PM
rob40cal's Avatar
rob40cal
Bismic, I tack welded mine in a few spots, and no warping went right back in no problem.
(Mig welder)
Old Jul 28, 2009 | 07:06 PM
bismic's Avatar
bismic
John / rob40cal - thanks for the tips. I will pass this on to my friend!
Old Jul 29, 2009 | 02:27 PM
DSMMH's Avatar
DSMMH
DSMMH - I appreciate the suggestions. I am not too worried about the EGR valve. It is an old style and a spare. I would not install it in the truck anyway. I will say that the friend who I asked to weld the valve is worried about warping it while welding. So I may be back to the epoxy idea. What type/brand of epoxy did you use?
I used epoxy that I glue golf shafts with. It takes a heat gun or torch to soften it after it hardens. With the EGR valve epoxyed shut, no exhaust gas flowing and the cooler working OK, there should be no issue with it breaking down. JB Weld should work fine.
DSMMH
madhatt
Feb 25, 2014 04:30 PM
MC5C
Mar 23, 2013 12:34 PM
h20ford
Feb 12, 2013 07:57 PM
StanleyZ
6.4L Power Stroke Diesel
Feb 27, 2012 11:08 AM
5xkmw
Mar 30, 2010 06:50 AM
