Dakota Digital
Old Jul 26, 2009 | 08:33 AM
rwlacks's Avatar
rwlacks
Dakota Digital
Thinking about buying there Instrument System # VFD3-73F-PU anyone useing one now ? And how do you like it ?
Old Jul 26, 2009 | 10:57 AM
Holiver31's Avatar
Holiver31
I don't really like the look of digital "gauges". But if someone bought me one I'd put it in. haha
Old Jul 26, 2009 | 11:06 AM
ranger429's Avatar
ranger429
I did the swap in my Bronco. I used the stock wiring and spliced the new connector into the OE harness. The gauge assembly comes with the new senders that are needed. You still retain the OE fuel sender and then calibrate the gauge pack to your sender. It was very easy to do. I still have to lay out a mile and calibrate the speedo. From passing radar boxes I am about 4 MPH off. They include a couple of momentary button's to get into the computer of the gauges to do all calibration.
The fit of the lens was absolutely perfect. I used some black sealer on the back side to set the lens in place. I also used a small air grinder to get rid of the material that was not needed. I'm thinking of doing this gauge pack in my 250 and the crewcab. It is a hell of alot more accurate and nicer looking than the original setup.
Finished:
Old Jul 26, 2009 | 03:14 PM
MT-F250's Avatar
MT-F250
I'd sure like to put that in my 79-F250. The price just seems a little high but probably worth it. I always thought it came complete but from your pic's it looks like just the seperate guages fit into the original cluster housing?
Old Jul 26, 2009 | 06:41 PM
77f2504by4's Avatar
77f2504by4
Originally Posted by ranger429
why does it say "please" under the speedo?
Old Jul 26, 2009 | 06:51 PM
MT-F250's Avatar
MT-F250
I don't know why I didn't notice that!
Probably means "please I really want one!"
Old Jul 26, 2009 | 07:40 PM
ranger429's Avatar
ranger429
The gauge packs are seperate and do require cutting your bezel. Not to hard to do and probably took me about 4 hours to do the complete install.
Please is on there the 1st time you turn it on, IIRC it said something like please set your mode or similiar.
Old Jul 26, 2009 | 10:06 PM
bucks77ford's Avatar
bucks77ford
I think I'll eventually get that for mine. Curious, can you set your odometer to whatever you want at the start?
Old Jul 26, 2009 | 10:31 PM
ranger429's Avatar
ranger429
No, it automatically starts at zero. I don't think you could set it to whatever you wanted.
Old Jul 26, 2009 | 11:24 PM
fatherdoug's Avatar
fatherdoug
What is involved with getting a voltage reading, instead of an amp reading?
Old Jul 27, 2009 | 12:30 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Only 13.1 volts?
Looks nice though ,didn't realize it requires cutting the bezel.
Josh
Old Jul 27, 2009 | 01:20 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
i successfully installed that cluster in mine, its frickin awesome, the 'please' is 'please set...whatever' that flashes across the bottom until you have it all set up correctly.
the unit is housed in a brushed aluminum housing, very precise manufacture, worth every cent.
Old Jul 27, 2009 | 01:36 AM
Skip1970's Avatar
Skip1970
how much does it cost? 100$?
Old Jul 27, 2009 | 01:48 AM
78_f800crewcab4x4
heck no, lol. try 600$somthin. considering theres a computer in there, 6 or so guages in there, a custom fit metal housing, sending units, wires, relay block. everything is labeled. and its made specifically for our trucks.
Old Jul 27, 2009 | 01:54 AM
Skip1970's Avatar
Skip1970
ouch! thats allot of $ for simple gauges.. are they at least all made in america? then it might be worth it.
Ray
