Dakota Digital
Old Jul 27, 2009 | 11:50 AM
ranger429's Avatar
ranger429
Originally Posted by fatherdoug
What is involved with getting a voltage reading, instead of an amp reading?
Dunno, you'd have to contact Dakota digital with that question.
Originally Posted by Bullitt390
Only 13.1 volts?
Looks nice though ,didn't realize it requires cutting the bezel.
Josh
Yes, this was just after finishing up the Bronco. It sits for a long time so the battery tends to drain a bit. Normal charging is fine though once it has been out a while.
Originally Posted by b-uno
ouch! thats allot of $ for simple gauges.. are they at least all made in america? then it might be worth it.
Ray
If you compare the price to what you would spend on aftermarket gauges it isn't that bad plus I can calibrate the speedo to accept the 35" tires.
Old Jul 27, 2009 | 03:06 PM
Skip1970's Avatar
Skip1970
i dont like the blue green color, i thnk it looks cheap, do they make it in red colored numbers? that would be cool looking.
Old Jul 27, 2009 | 03:27 PM
ranger429's Avatar
ranger429
There were 2 colors offered, I think the other one was a green color.
Old Jul 27, 2009 | 03:45 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Dang, tell us how you really feel.
My Nissan Maxima has reddish/ orange and it drives me nuts.
Josh
Old Jul 27, 2009 | 03:49 PM
ranger429's Avatar
ranger429
That's all right, I'm not offended. Some people only have taste in their mouth.
Old Jul 27, 2009 | 03:54 PM
Skip1970's Avatar
Skip1970
not meant to offend, sorry if my color preference may have, just red is allot nicer for nite time driving, being im in alaska its dark 1/2 the year.
Old Jul 11, 2010 | 02:08 AM
wadar1969's Avatar
wadar1969
Bucks77ford, Dakota Digital will put whatever miles you want on the cluster for $20 when you oreder them. Im looking into getting them also. I have been looking at them and the ones that are available through ezwiring.
Old Jul 11, 2010 | 09:14 AM
SGT_DENTSIDE's Avatar
SGT_DENTSIDE
I looked at the panels from ezwiring and I cannot tell how that panel would fit in the truck. Anyone have any pictures of the ezwiring kit installed?
Old Jul 11, 2010 | 06:11 PM
wadar1969's Avatar
wadar1969
Yea SGT I have been waiting to see some installed pics of the of the Dolphin gauges and panel from EZwiring
Old Jul 12, 2010 | 09:02 AM
SGT_DENTSIDE
I sent ezwiring an email yesterday and asked for some pictures of the panel installed in a dent. We will see if they have any.
Old Jan 12, 2011 | 12:11 PM
madeinthe70s's Avatar
madeinthe70s
Originally Posted by ranger429
I did the swap in my Bronco. I used the stock wiring and spliced the new connector into the OE harness. The gauge assembly comes with the new senders that are needed. You still retain the OE fuel sender and then calibrate the gauge pack to your sender. It was very easy to do. I still have to lay out a mile and calibrate the speedo. From passing radar boxes I am about 4 MPH off. They include a couple of momentary button's to get into the computer of the gauges to do all calibration.
The fit of the lens was absolutely perfect. I used some black sealer on the back side to set the lens in place. I also used a small air grinder to get rid of the material that was not needed. I'm thinking of doing this gauge pack in my 250 and the crewcab. It is a hell of alot more accurate and nicer looking than the original setup.
Finished:
Looks great. I'm about to install this in my 79 Bronco. Where did you mount the control box?
Old Jan 13, 2011 | 08:04 AM
ranger429's Avatar
ranger429
Control box was mounted under the dash. Gauges still work great.
Old Jan 13, 2011 | 08:10 AM
  #28
Redneckryder's Avatar
Redneckryder
I have seen his bronco....If possible, those gauges look even nicer than the picture gives the credit for. Very clean, very nice presentation.
Old Jan 13, 2011 | 08:54 AM
  #29
fellro86's Avatar
fellro86
Ray
Can't say on the components they use for sure, but they are located in Sioux Falls, SD, and put it together there. They pretty much can custom build a setup for any vehicle if you pay them enough. They aren't really a volume builder, so you will pay a bit more to have them build the units.
FuzzFace2
WTB - Parts & other
Oct 23, 2016 06:54 AM
07EXPYEL
Jun 7, 2016 11:51 AM
FuzzFace2
15
May 21, 2016 09:53 PM
Elmo154
Vehicles for Sale
Apr 19, 2016 02:58 PM
bismic
Aug 10, 2015 10:35 AM
