Bilstiens with 2.5" level
Old Jul 26, 2009 | 12:26 AM
crazymut's Avatar
crazymut
I am looking at getting a 2.5 inch leveling kit, I also need new shocks, does anyone know which Bilstiens to use for this application? Thanks
Old Jul 26, 2009 | 12:36 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You want shock part # F4-BE5-6246-H6
Old Jul 26, 2009 | 12:42 AM
crazymut's Avatar
crazymut
Thanks for the help.
Old Jul 26, 2009 | 09:30 AM
DCSpecial's Avatar
DCSpecial
6246s are rear shocks for 1-3" of rear lift (used with 3-6" front lift).
With 2.5" leveling systems it depends on what type of leveling system it is.
You'd either use the 0-1" fronts or 1-3" fronts.
I'd do the 0-1" rears either way.
Old Jul 26, 2009 | 11:26 AM
kupaa's Avatar
kupaa
Last month i installed a 2.5 leveling kit from Tuff Country and before i installed the kit the front was 2.5 inches lower then the rear(thats why i used a 2.5 kit)after the install of the kit it is now 2 inches higher then the rear which gave me a lift of over 4 inches now the rear squats down so i have to lift my rear 2 inches to level the truck which comes to the question,which shocks do i need.BTW i will use the factory 4 inch rear blocks from a F-350,Is there a shock part # for the factory lift.Hope i didn't confuse anyone.
Old Jul 26, 2009 | 06:48 PM
big poppa's Avatar
big poppa
I have a 2 inch shackle kit on mine and it sits level, but when I hook up my camper, it drops in the back so i,m going with the F-350 blocks also, thanks to a FTE member here I should have them on by weeks end..we'll see. I went with the regular heavy duty Bilstiens, no lift, just replacements. I don't have the part numbers off hand..
Old Jul 26, 2009 | 07:33 PM
Riffraff Diesel
PREMIUM SPONSOR
Your right, sorry about that. So it must be the BE5-2818-H0?
Old Jul 26, 2009 | 11:40 PM
DCSpecial's Avatar
DCSpecial
That's a 0-1" 5100 yellow body blue boot.
If it's a hanger and shackle 2.5" it would be a A463 which is a 1-3" shock silver body, black boot.
And there is a 5125 shock (generic valving, silver body black boot, 1yr warranty) you can get that's the same length as the 2818 if you don't like the yellow and blue.
Of course the Zinc and CAD finishes due rust if left untreated in areas where they use road salt.
Old Jul 26, 2009 | 11:47 PM
crazymut's Avatar
crazymut
What is the normal life span of the Bilstiens? I have some that are about four years old and they seem to be worn out. Of course my springs are also done so there is more stress on the shocks without the springs helping.
Old Jul 27, 2009 | 02:22 AM
kupaa's Avatar
kupaa
Mike,let me know how that works out for you.
Cofcmsc
2004 - 2008 F150
Sep 15, 2012 08:07 PM
smokin_6.0
6.7L Power Stroke Diesel
Feb 28, 2012 05:57 PM
shamrock442
Mar 21, 2007 09:51 PM
Shad's EX
Jul 15, 2005 10:51 PM
Badford
Nov 24, 2003 08:26 PM
