Sponsored by: Real Truck
need shock info???
Old Nov 21, 2003 | 11:20 AM
Badford's Avatar
Badford
need shock info???
i need new shocks for my truck with a 2.5 inch lift. which are best and what is the best place to buy them cheapest.
im looking at bilstien 5100's , rancho RSX, and trailmaster SSV
THANKS
FOR ANY INFO
Tony
Old Nov 22, 2003 | 04:52 PM
Badford's Avatar
Badford
i talked to a guy today who said bilstein does not offer shocks for 2.5 inch lift. so they are out of the search!
Tony
Old Nov 22, 2003 | 05:51 PM
DCSpecial's Avatar
DCSpecial
Bilstien 5100s are available for 0-2" lift in the BE5-2818-HO front and BE5-2819-HO rear and 3-6" lift in the BE5-6245-H5 front and BE5-6246-H5 rear. What is the measurement from shock eye to shock eye in the front of your truck with the 2.5" lift?
I like the Bilsteins myself.
I have Rancho 9000s....don't like them as much.
Hope this helps.
Old Nov 22, 2003 | 10:39 PM
DeerSniper's Avatar
DeerSniper
How much are Bilsteins for a 6" lift?
Old Nov 23, 2003 | 01:59 AM
Justwingem's Avatar
Justwingem
DeerSniper
The 5100 series are around $75 each and the 5150 which have fixed crossflow reservoir damper are $100 each. 6.5 inches of travel up to 14 inches.
Great ride on either just be sure they are valved for you application when you order them.
Old Nov 23, 2003 | 03:40 AM
Autobahn F-250 Lariat's Avatar
The following info came from ORW
Bilstein - Oem Replacement for '99-'02 Ford F250/350 S/D 4wd
Fronts #BE5-2818 $60.99
Rears #BE5-2819 $60.99
Bilstein - 5100 Series for Lifted '99-'02 Ford F250/350 S/D 4wd
Fronts (4-6" lift) #BE5-6245-H5 $75.99
Rears (0-2" lift) #BE5-6246-H0 $70.99
Just my $.02.
Manny
Old Nov 24, 2003 | 02:50 PM
DeerSniper's Avatar
DeerSniper
Thanks for the info.
Old Nov 24, 2003 | 05:27 PM
HIROLLN's Avatar
HIROLLN
Bilstein's hands down! I as well HAD rs 9000 they sucked!
Old Nov 24, 2003 | 08:26 PM
DeerSniper's Avatar
DeerSniper
I have a bit of a problem, where is a rear shock for a 6" lift? I can only find those 0-2" shocks for the rear. I want to go Bilsteins at every corner. Where can i find some for a 6" Skyjacker lift?
Thanks.
laketrout
1997 - 2003 F150
38
Apr 30, 2007 05:02 PM
boatman83
Apr 14, 2004 04:35 PM
KennyG228
Apr 2, 2004 06:47 PM
maxray
Mar 18, 2003 12:34 AM
weldman
Dec 6, 2002 01:48 AM
