tach reads high
Old Jul 24, 2009 | 06:29 PM
Diesel_Brad's Avatar
Diesel_Brad
tach reads high
In my Lightning, my tach reads 500-100 above where is should. Any ideas? O and it has the white face overlay in it to.
Old Jul 24, 2009 | 06:43 PM
DBGrif91's Avatar
DBGrif91
How can you tell that the tach is reading high?
Old Jul 24, 2009 | 07:45 PM
Neptoess's Avatar
Neptoess
i'd like to hear this one as well. unless it's reading like 1500 at a noticeably normal idle, i have no clue how youd know unless you had a really good ear from years of driving sticks and staring at the tach
Old Jul 24, 2009 | 07:50 PM
Virto's Avatar
Virto
It's been said that the factory tachs aren't particularly reliable or accurate. Have you checked it with an aftermarket tach from the coil?
I've seen a number of theads where people have factory tachs running 200-500 rpm higher than aftermarket. I'm not sure if they were just built with poor tolerances or if they have a moderate-high failure rate.
I know the circuit paper in the dentsides rots away causing all kinds of problems. Not sure, but there might be some kind of poor connectivity with the cluster.
Old Jul 24, 2009 | 08:02 PM
Neptoess's Avatar
Neptoess
i wouldnt waste the money on an aftermarket tach unless you're doing competitive racing or something. most of the time you don't even need to look at your tach to know when to shift, it's more of a feel you develop. when trying to get absolutely perfect shifts though an accurate tach is almost essential.
Old Jul 24, 2009 | 10:56 PM
Diesel_Brad
Had the truck out tonight(only put about 3k on a year) The tach was reading about 2000-2500 at an idle. And no, it was not idling high, only about 700rpm
Old Jul 25, 2009 | 12:23 PM
Neptoess's Avatar
Neptoess
i'd check the wiring on the back of the tach. i can type out the chiltons procedure for taking apart the instrument panel if you need it
Old Jul 25, 2009 | 04:37 PM
Diesel_Brad
Na, thats ok. I can have the cluster out of these trucks in under 2 min
genscripter
May 8, 2015 05:47 AM
Aune163rd
Dec 13, 2014 08:02 AM
sams6.9
Apr 15, 2014 06:21 PM
BDawg171
Mar 27, 2011 10:43 AM
bbull55
Jan 21, 2009 03:21 PM
