new computer made things worse
Old Jul 24, 2009 | 06:32 PM
frankyford's Avatar
frankyford
Is there something I was suppose to do when I hooked up the new computer in my 95 F-150 302 auto. I took the old one out and plugged in the new one the same way. I had the battery disconnected, was I suppose to do something else. Thanks
Old Jul 24, 2009 | 06:41 PM
DBGrif91's Avatar
DBGrif91
Direct quote from my Chiltons manual for 87-96 pick ups when replacing or repairing the PCM:
If the battery cable(s) is disconnected for longer than 5 minutes, the adaptive fuel factor will be lost. After repair it will be necessary to drive the truck at least 10 miles to allow the processor to relearn the correct factors. The driving period should include steady-throttle open road driving if possible. During the drive, the vehicle may exhibit driveability symptoms not noticed before. These symptoms should clear as the PCM computes the correction factor. The PCM will also store Code 19 indicating loss of power to the controller.
Old Jul 24, 2009 | 06:45 PM
frankyford's Avatar
frankyford
Thanks, I'm going to give it a shot. Hopefully I won't shut down on me. Thank you for looking that up for me, I'll let you know how it goes.
Old Jul 24, 2009 | 06:50 PM
DBGrif91's Avatar
DBGrif91
No problem- hopefully this straightens it out.
Old Jul 24, 2009 | 07:23 PM
frankyford's Avatar
frankyford
Sorry, no change pulled codes on it. This what I got,
172= HEGO shows system always lean
33= EGR valve opening not detected ( new EGR and new EGR solenoid)
45=Thermactor air upstream during self- test
38 (could be 48 couldn't find 38)but 48 is Loss of IDM, leftside whatever an IDM is
53=TP circuit above max voltage
66-MAF sensor input below min voltage
32=EVP voltage below closed limit
Some of these codes I didn't get off the old computer and on the passenger side of the engine it alot hotter than the driver side and can still smell raw gas, so the cats may be getting to hot.
Old Jul 24, 2009 | 07:49 PM
Neptoess's Avatar
Neptoess
your 95 isnt throwing 2 digit codes at you unless you replaced it with an older computer. in that case, that may be the problem
Old Jul 24, 2009 | 08:03 PM
frankyford's Avatar
frankyford
I've got an ODB-1 computer, and the one I got I just bought today was a reman. It is throwing 2 digit codes and 1 3-digit code.
Old Jul 24, 2009 | 09:38 PM
EPNCSU2006's Avatar
EPNCSU2006
That isn't possible. It will output either 2-digit codes or 3-digit codes, but never both from the same computer.
Old Jul 25, 2009 | 05:24 AM
jr32560's Avatar
jr32560
are we sure on this
Old Jul 25, 2009 | 05:39 AM
frankyford's Avatar
frankyford
Well I'm telling ya'll this has got me stumped and about broke trying to fix it, I've put about close to $600 in parts on it so far and nothing has changed. This including the new PCM, EGR valve, EGR solenoid, TPS sensor, coolant temp sensor, FPR, MSD Ign coil, IAC. I've taken off and cleaned the TB and removed gunk fromthe upper intake plenum and no change. And the bad part is I can't give up on it cause I need the vehicle and can't afford to go buy a new one. Sorry for the sob story, just frustrated about the whole thing. It's probably something so simple and stupid I'm missing it.
Old Jul 25, 2009 | 05:54 AM
DBGrif91's Avatar
DBGrif91
Hmm... MSD ignition coil? Are you running a stock engine? Do you have the other components to support an MSD ignition system such as plugs and wires? If not, then that could be the source of at least some of your problems. You can't have just one component of an advanced ignition system such as MSD without having them all. Well, I guess technically you can, but then you end up with problems.
The only thing I can suggest right now is that you either replace the ignition coil with a stock one or buy the rest of the components necessary for an msd system. At this point the coil is the cheapest option.
Old Jul 25, 2009 | 05:59 AM
frankyford's Avatar
frankyford
It's not the big performance one that I got. It's just the one that goes to our trucks in the stock location. Besides I've was having this problem before the ign coil was replaced, I just thought the old one was no good judging from the tip of it was half gone. So upgraded a little bit to see if that would help, but it hasn't.
Old Jul 25, 2009 | 06:03 AM
EPNCSU2006's Avatar
EPNCSU2006
The MSD coil should work fine with the stock ignition system. I've never had any problems with the one on my truck.
are we sure on this
absolutely
Old Jul 25, 2009 | 06:15 AM
DBGrif91's Avatar
DBGrif91
Fair enough... it's just been my experience that if you use one component of an advanced ignition system you should use them all. But then, this comes from installing these systems on cars instead of pick ups.
If they have an msd coil that works with stock Ford pick ups- great.
So here's my next question- you've replaced a lot of sensors already, what sensors HAVEN'T you replaced? You might start by checking those out- you'd be surprised how one incorrect reading off a sensor by the PCM can screw things up. If you don't have a service manual, let me know which sensors you want to check and I will look up the procedures for you.
BTW, to determine what type of computer you have [in case you aren't entirely sure] just count the number of pins in the connector. An EEC-IV comp uses a 60 pin connector and an EEC-V uses a 104 pin.
Old Jul 25, 2009 | 06:21 AM
frankyford's Avatar
frankyford
I know for sure the TAD and TAB haven't been replaced yet(thanks EPNCSU2006), but how many more do I have other than the ones I posted so far. I've put so much on this truck I can't remember all the crap I've put on it, I'm losing track of all of it.
