Tach stuck and reading high?
Old Jan 21, 2009 | 10:31 AM
bbull55's Avatar
bbull55
Been extremely cold here the past 2 weeks in PA. This is when my tach started acting weird. When the shut the truck off it it stuck at like 3k. Then when I start it up it continues to read high? Any suggestions to why this may be happening? The truck itself isnt running abnormal, just the tach reading? Is it due to the cold? Dont know anything about how tachs work? Any help is appreciated. I drive an 06 PSD...
Old Jan 21, 2009 | 10:34 AM
UGA33's Avatar
UGA33
This is a known problem with the truck especially the 06's for some odd reason. I had it happen to mine. Dealer put in a new instrument cluster under warranty and all is well
Old Jan 21, 2009 | 03:21 PM
EZ-Ford's Avatar
EZ-Ford
You may want to put the cluster into it Test Mod. This will exercise all the guages.
Before turning the key, press and hold the Trip button, then turn the key ON (not start). The ODO will display TEST, then release the button. You can now start the truck. Now with each press of the Trip button it will cycle through various readings. One of the first is Guage. This sweeps all the guages full sweep then returns to normal. Here is a link for more info:
https://www.ford-trucks.com/forums/6...ml#post4940556
DieselRugger
Dec 15, 2022 01:33 AM
jayjordon
Oct 19, 2016 05:14 PM
Blurple03
Aug 26, 2016 08:11 PM
fordtrucksforever
Jun 26, 2016 03:02 PM
carsronnie86
May 24, 2016 04:22 PM
