2005 Excursion climate system issues
Old Jul 22, 2009 | 07:48 PM
saltflatsracing's Avatar
saltflatsracing
My 2005 EX has had its first real problem.
Seems like the climate system started having a mind of its own.
as soon as you turn the ignition key on,the blower fan is at full speed.
with the engine running i'm unable to turn the climate system off or turn down the fan speed.
has anyone had this problem with their EX?
your help will be appreciated.
Old Jul 22, 2009 | 08:01 PM
Rickx's Avatar
Rickx
Are you sure it's not on Auto?
Old Jul 22, 2009 | 08:51 PM
Schmitty133's Avatar
Schmitty133
Even if it's on Auto you should still be able to turn it down.
Is there anything displayed on the screen? Mine blanked out, but the fan was not on. I had to cycle the ignition to reset it.
Schmitty
Old Jul 22, 2009 | 11:15 PM
REDNEXXXCURSION's Avatar
REDNEXXXCURSION
Blower motor relay switch from your local ford dealer and tell them you have an excursion with climate control fixed mine !
Old Jul 22, 2009 | 11:30 PM
saltflatsracing
i was thinking about the blower motor relay or power stage of some kind myself.
thanks for the help guys.
i will follow on your suggestions and let you know the results.
Old Jul 23, 2009 | 10:20 PM
REDNEXXXCURSION
Hope it helps, I only had high or nuthin almost froze a couple times ! LOL
Jarhead97
Nov 20, 2012 06:40 AM
JD603969
2004 - 2008 F150
May 3, 2012 06:01 AM
PeeWeeRacer
Jul 31, 2008 07:06 PM
Roadkingjdl
Jan 14, 2008 04:42 PM
cody47
Aug 9, 2005 03:10 PM
