Climate control fan speed under acceleration
Old Jul 19, 2008 | 11:49 PM
PeeWeeRacer's Avatar
PeeWeeRacer
Recently, I have noticed a strange problem with my Ex's climate control. The fan speed increases as I accelerate? Any idea on what's happening?
Old Jul 20, 2008 | 07:39 AM
projectSHO89's Avatar
projectSHO89
Manual or auto climate control?
Which mode? Norm, MAX, etc...
Any change of headlight brightness at the same time (possible over voltage from alternator)?
Steve
Old Jul 21, 2008 | 12:46 AM
RACERX7775's Avatar
RACERX7775
i doubt that its an OVER charge symptom. its more like when you come to a stop and the engine is at idle, the alternator is putting out less voltage. when you accelerate, you are spinning the alternator faster and that means you are now giving the optimium voltage to your vehicle.
put a volt meter on your battery.
start the engine and turn everything on, headlights, a/c, wipers and so on.
at idle, measure the voltage at the battery.
at 2000 rpm's, measure the voltage.
you will see a difference on the voltage.
do this after the engine has been at operating temp. your alternator will put out more amps when cold than when hot.
finally, your situation is perfectly normal......
Old Jul 21, 2008 | 05:51 AM
FordxFour's Avatar
FordxFour
My 05' doesn't do this. What condition are your batteries in ?
Old Jul 21, 2008 | 06:12 AM
PeeWeeRacer
I have the "Auto" version of climate control. However, I had a chance to take the Ex for a spin over the weekend and I am now questioning my original diagnosis that it was the climate control fan? A few more observations...
1) Velocity of the air coming out of the vents does NOT increase (despite sounding as if it does)?
2) When I turn the climate control panel to off, I still hear what sounds like the fan speed increasing?
3) The condition exists only when hard accelerating the Ex as I go down the road. It does not occur when the truck is in "Park" and I rev up the RPM's?
Old Jul 21, 2008 | 10:21 AM
RACERX7775's Avatar
RACERX7775
possible vacuum issue???
Old Jul 21, 2008 | 10:30 AM
jpr38057's Avatar
jpr38057
You are possibly hearing the fan clutch locked.
Old Jul 31, 2008 | 07:06 PM
PeeWeeRacer
PROBLEM SOLVED!! Turned out not to be the climate control after all. There was a crack in the rubber connector that attaches to the turbo cooler (the blue one). Replaced with ford part number 6C3Z-6C640-C. Just in time for a major road trip!!
Soundman7
Jun 14, 2013 10:24 AM
warriorm
Jul 7, 2012 08:23 PM
JD603969
2004 - 2008 F150
May 3, 2012 06:01 AM
"Eddie_B_Bauer"
Mar 22, 2004 09:43 AM
TCExp
Apr 13, 2003 03:17 PM
