My 2005 Ford F-150 Lariat 4x4 5.4l V8. the climate control system will not let me lower the fan speed or let me change the airflow direction. and my heated seats will not work as well.. i looked at the fuse it was good.. and un-plugged the battery for 3 minutes.. any other suggestions?
If you have the "automatic" climate control, there is a self diagnostic capability. I know my brother's Taurus has that type A/C system. We ran the test, got the "fail code", replaced a faulty sensor ($25 from Tasca). Everything is like new now. I'm not sure if the test works the same as on his car, maybe somebody here has a little knowledge?
Here's the link to the Taurus thread if you want to give that a try...
