e4od won't budge
Old Jul 22, 2009 | 06:45 PM
nomad221's Avatar
nomad221
e4od won't budge
Doing the auto to man. swap and can not remove the e4od. Flex plate bolts are off, converter housing to block bolts are out, crossmember is out, engine supported, starter removed and the exhaust is not in the way. I can't see anything blocking the tranny. I laid under the truck and kicked the output housing, still nothing. Any tips guys ?
Old Jul 22, 2009 | 07:41 PM
ssquints999's Avatar
ssquints999
i have never removed a tranny before but i didn't see anything metioned about TQ bolts. hopefulling someone else will chime in.
Old Jul 22, 2009 | 07:54 PM
Michiganford's Avatar
Michiganford
um, dumb question, driveshaft out???
Old Jul 22, 2009 | 07:56 PM
4wheeling79's Avatar
4wheeling79
I bet the dowel pins are stuck you are going to have to get a pry bar in between the motor and tranny and pry it a part.
Old Jul 22, 2009 | 09:06 PM
nomad221's Avatar
nomad221
Thanks guys, it was the dust shield. Removed the two bolts on either side of the inspection plate and the tranny came free. ZF will be installed tomorrow.......time for some suds.....
F250F250F250
38
Jan 25, 2016 04:41 AM
danlee
Aug 17, 2012 06:20 AM
Greg5OH
May 16, 2012 11:33 AM
Hilux
Oct 12, 2009 04:38 PM
Erickson
Jan 1, 2004 04:20 PM
