c6 tranny
Old Jul 22, 2009 | 04:10 PM
david67's Avatar
david67
c6 tranny
I'm looking for a C6 tranny to bolt up to a 352 FE in my '67 F100. Anybody know of one available?
Thanks,
David
Old Jul 23, 2009 | 06:50 AM
60F100's Avatar
60F100
There should be a lot of C6 trannys out there. If it is behind any FE it should fit. Look for 360s and 390s from 68 thru mid 70s. The C6 out of cars should also work. Some have different tailshafts but you will probably have to get a different driveshaft anyway.
Old Jul 23, 2009 | 06:55 AM
ford390gashog's Avatar
ford390gashog
There is a endless supply of them all the trucks til 76 used them behind the FE's there should be no shortage. I know there is atleast 15 at my local wrecking yard at all times.
Old Aug 14, 2009 | 09:25 AM
david67's Avatar
david67
I posted a new thread today...got another 67 with aN NP435 4-speed that I will be using instead of a C6...
Old Aug 14, 2009 | 10:48 AM
jowilker's Avatar
jowilker
I want to throw in 2 pennys worth here. The car C6s have a different shift arm on the side of the tranny from trucks. While both are pretty much the same inside a C6 from a truck will give you a better shifter selection.
Mine came from a car and I couldn't go to low. Got the arm changed last year and now everything is much better.
John
david00f150
1966 - 1977 Early Broncos
77
Mar 19, 2014 01:05 PM
dwayrynen
Dec 12, 2010 04:21 AM
araiderfan2001
Apr 27, 2003 11:29 PM
dbarracuda
Feb 28, 2003 09:48 AM
David
1978 - 1996 Big Bronco
Oct 22, 2001 05:58 PM
