C4------>C6 Swap
Old Apr 27, 2003 | 09:22 AM
araiderfan2001's Avatar
araiderfan2001
C4------>C6 Swap
I've got a '77 F100 that has a 302/C6. It had a C4 before and nothing was changed when the C6 was put in. Does a C6 require a different crossmember? Also the linkage is rigged up badly, does anyone know what part # is required to go from the steering column to tranny for this setup?
Thanks!
David
Old Apr 27, 2003 | 11:29 PM
AggiePSD's Avatar
AggiePSD
C4------>C6 Swap
You can use the same crossmember but it must be moved rearwards on the frame. I dont have that part number, but I know that it needs to be extended an inch or two. I just welded a bolt onto it to extend it. Cheap and easy.
dmanlyr
Large Truck
May 2, 2014 08:10 PM
david00f150
1966 - 1977 Early Broncos
77
Mar 19, 2014 01:05 PM
david00f150
Modular V8 (4.6L, 5.4L)
13
Jul 28, 2010 08:25 AM
david67
Aug 14, 2009 10:48 AM
f100beatertruck
Apr 26, 2003 10:25 AM
