E4OD code 628 - TC or solenoid?
Old Jul 20, 2009 | 09:17 PM
jlarr's Avatar
jlarr
1993 F150 4x4 5.0L E4OD 150K miles
I’ve had this truck since new and have changed the trans fluid (including converter) and filter every 30K miles. I don’t tow with it and don’t 4-wheel with it. It’s just a car to me.
Four years ago, I lost overdrive (threw code 628-excessive torque converter clutch slippage) and was able to get things working again by changing all the fluid and filter.
Recently, I started to get an intermittent shudder/bucking just after the 3-4 upshift at 36mph under very light throttle, once the truck warms up. It's at about 1150 rpm. As before, no TCIL light flashing, but it threw code 628 again (no other codes). It would also intermittently “burp” at idle. The last symptom is an intermittent slight hesitation at take off, like something’s not catching for a second.
I changed the fluid/filter and added a quart of TransX, but no change. The pan was clean as ever and the fluid was not burnt. I have checked the TPS, ECT sensor, VSS, EGR sensor, and all are OK. I updated the MLPS about a year ago. The fuel filter, cap, rotor and wires are relatively new, and I’ve recently cleaned the injectors. My speedo works fine, there are no other symptoms. It shifts great.
My research leads me to either the torque converter or TCC solenoid in the solenoid pack. I pulled the solenoid pack plug and it was clean. I repacked it with dielectric grease and plugged it back in. Still have the problem.
My questions are:
-How do I test the TCC solenoid without the special Ford tool? I’m sure it has power, as the trans shifts. But, I’d like to know if I can test the TCC solenoid externally. If so, I’d think I need a schematic of the plug.
-What are the chances the solenoid is bad versus the TC being worn out? I believe the trans is OK, as it shifts just fine. The solenoid and TC cost about the same money, but the solenoid pack is much easier to install.
I was just about to put the truck on the market when this started. I don’t want to try to sell it this way, but I’m also not dumping a $2500 trans into a ~$4000 truck. I’ll spend $200 on a TC or solenoid pack, if that’ll fix it. Any input is appreciated.
Old Aug 10, 2009 | 07:56 PM
jlarr's Avatar
jlarr
Update to original post...
I still haven't done anything, but notice that intermittent idle "burp" happens more often and stronger when A/C is on. Also, I get the intermittent shudder when I have O/D off, just not as often and not as strong.
Anybody with any ideas, please chime in.
Old Aug 11, 2009 | 11:03 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The solenoid can be checked with any ohm meter. All you are looking for is resistance across the solenoid's coil. I forget the exact reading, I think it is about 10-20 ohms. If it's bad it usually become infinite resistance, i.e., an open circuit. I don't have a wiring diagram handy to be able to tell you which pins it uses.
Most likely it's the torque converter. There was a problem with E4OD torque converters cracking the piston that applies the torque converter clutch. That reduces the pressure that's applying the clutch, and it starts to slip.
Old Nov 25, 2014 | 11:18 AM
RevMarkM's Avatar
RevMarkM
My 1993 Ford F150 will not fire. I have replaced The ICM, The Coil, and the Distributor. Does anyone have a wiring Schematic for this thing. I'm an old IBM Electronics guy. this would help. Any, other wonderful words of advice would be appreceiated.
Thanks!
Mark
Old Nov 26, 2014 | 11:26 AM
Island Time's Avatar
Island Time
Thanks!
Mark
Mark, Welcome to FTE. You'll find a bunch of really knowledgable and helpful folks who are more than willing to lend you a hand. Your best bet in getting the help you seek is to post your request in the correct sub-forum and by starting a new thread specific to your problem. Try reposting your request in the 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Dec 31, 2014 | 01:01 PM
RevMarkM's Avatar
RevMarkM
Inertia Switch
Where would the Inertia switch be located at on this 1993 F-150 5.0L Nightmare...lol I had a neighbor say he had one that went bad and had to replace it. What do you think. And I did have a thread for all of this but, I forgot my pass word and everything went to the wayside...lol
Old Jan 4, 2015 | 08:22 PM
Island Time
Did you read the response to your previous post? Writing a post asking where the inertia switch is in this forum is like asking how to repair a DASD device in the keypunch forum. You're not going to get much help. Post this inquiry in the forum for your '93 truck.
Old Jan 4, 2015 | 09:47 PM
85e150's Avatar
85e150
Right side under dash behind trim panel.
Part 2 -How to Test the Fuel Pump (Ford 4.9L, 5.0L, 5.8L)
tbon63
Jun 20, 2021 04:14 PM
Frank250Tank
Jul 1, 2016 07:12 AM
NinthGenF-SeriesOBS
Apr 24, 2016 01:09 PM
KING-RANCH02
1997 - 2003 F150
Dec 9, 2015 08:43 PM
Claybeaux232
Sep 9, 2015 09:17 PM
