OBD-1 KOER code 623 question
Old Apr 24, 2016 | 08:25 AM
NinthGenF-SeriesOBS's Avatar
NinthGenF-SeriesOBS
Vehicle: 1994 F250 HD 4X4 w/ a 460 and E4OD
Performed a KOER test to see if any other codes came up about the trans. My trans goes into "safe mode" and kicks and I get code 628(I think) which is excessive TC clutch slippage. When doing the test I got code 632(Torque Converter Solenoid Circuit Did Not Change States During KOER). Should the TC solenoid circuit change during the test? If it should have and didn't then I'm thinking this may be causing my code 628 but I'm not a trans tech so in asking here. If not then a new TC for me then.
Also what torque converter should I buy? And for how much? I'd like to spend under $200 but at this point I know what I like and get aren't always the same lol. Thanks
Old Apr 24, 2016 | 11:17 AM
Lead Head's Avatar
Lead Head
Code 632 is not Torque Converter Solenoid Circuit Did Not Change State. It just means you didn't press the O/D cancel button on the shifter.
Old Apr 24, 2016 | 01:09 PM
NinthGenF-SeriesOBS
OK because according to troublecodes.net it said it was.
http://www.troublecodes.net/ford/eec-iv/
NinthGenF-SeriesOBS
Mar 26, 2016 09:47 PM
69ford99
1997 - 2003 F150
Dec 17, 2015 11:27 PM
HVJ
Jan 21, 2005 12:10 PM
jwdenney2
Apr 14, 2003 01:32 AM
Gannet
Jun 24, 2001 09:37 PM
