low brake switch
Old Jul 17, 2009 | 05:37 PM
jeff gammon's Avatar
jeff gammon
low brake switch
Where is it located. The switch that causes the brake light to light up on the dash of a 1978 f100
Old Jul 17, 2009 | 05:44 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's on the proportioning valve, located under the master cylinder.
Josh
Old Jul 17, 2009 | 05:48 PM
Mr. Green Jeans's Avatar
Mr. Green Jeans
I believe on most of our trucks it is called a Brake Proportioning Valve. On my '77 it is near frame rail, drivers side, under cab. I think its called the pressure switch that screws into this valve and signals light on dash.
Old Jul 17, 2009 | 06:19 PM
Bullitt390's Avatar
Bullitt390
Your valve is way under the cab? Interesting, mine is mounted on a bracket right above the steering box.
Josh
Old Jul 17, 2009 | 06:53 PM
alconk's Avatar
alconk
My 79 is located in the same place as yours.
Old Jul 17, 2009 | 06:55 PM
ford390gashog's Avatar
ford390gashog
4wd trucks its by the frame rail 2wd trucks its mounted on a bracket above the steering box.
Old Jul 17, 2009 | 07:27 PM
a truck named effy's Avatar
a truck named effy
Mine is under the cab by the frame rail as well, "1977 F100 302 2WD Man-Steering Man-Brakes. I thought of moving mine up near or next to the master cylinder but was unsure of the purpose of the lengths of coiled steel line running to the valve. Could there be a problem if the lines from the MC to the prop valve were only 6"-1' long?
Old Jul 17, 2009 | 11:55 PM
alconk's Avatar
alconk
Mine is a 2wd and is not above the steering box. It's down somewhat under the cab mounted on a crossmember
Old Jul 18, 2009 | 12:27 AM
Bullitt390's Avatar
Bullitt390
Can you guys take a picture of this? Pretty curious about why Ford changed the location like that.
Josh
Old Jul 18, 2009 | 03:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C8AZ2B264A .. Low Brake Fluid Warning Lamp Switch / Available from Ford / Threads into the brass Brake Differential Proportioning Valve.
This valve could be located in three possible locations:
1) Below the master cylinder adjacent to the steering gearbox.
2) Bolted to the outside of the left frame rail directly behind the left front wheel.
3) Bolted to the outside of the left frame rail to the rear of the steering gearbox.
The low brake fluid switch is plastic, develops cracks in the threads, causing fluid to seep out.
When that occurs, the low brake fluid warning light on the dash comes on...and stays on.
C8AZ2B264A fits: 1968/79 F100/350 / 1968/79 Bronco / All 1968/69 Passenger Cars / 1969/79 Econoline.
MSRP: $33.64 // FTE sponsor: y2kfordparts.com price: $18.17.
Old Jul 18, 2009 | 08:53 AM
Bullitt390's Avatar
Bullitt390
So it's the same valve for all trucks, but they kept changing the location? Interesting...
Josh
Old Jul 18, 2009 | 10:43 PM
NumberDummy
Originally Posted by Bullitt390
So it's the same valve for all trucks, but they kept changing the location? Interesting.Josh
The low brake fluid warning light switch (C8AZ2B264A) is the same, but...
The proportioning valves are not the same.
It depends on the year, series, 2WD or 4WD and in some cases, the GVW.
The OP has a 1978 F100.
D5TZ2B257B .. Brake Differential Proportioning Valve / Marked: D5TA-2B524-FA or FB.
Fits: 1975/79 F100/150 2WD/4WD with disc brakes / 1975/79 F250 2WD with a GVW of 6200 lbs. (single piston calipers).
Fits: 1976/79 F250 4WD / 1979 F350 4WD.
Fits: 1976/77 U100 with disc brakes / 1978/79 U150 (U = Bronco).
Fits: 1975/79 E100/150 (E= Econoline).
There are FIVE other valves listed for the rest of the 1973/79 F100/350's. Two of these same valves fit 1975/79 E250/350's.
Shadowrider123
Mar 3, 2015 12:55 PM
Pappys53
May 18, 2013 01:51 AM
beckman
May 10, 2013 09:56 AM
Larzon
Nov 18, 2012 06:56 PM
