C6 kickdown
Old Jan 17, 2001 | 09:47 AM
heavymetal's Avatar
heavymetal
C6 kickdown
I have a c6 and my question is is kickdown accoplished through the modulator valve without the need for a kickdown rod?
Thanks for any input...
HeavyMetal (Rod)
1977 F100 429CJ bored 30 over, Heads milled 30, edelbrock performer cam, intake, lifters, valve springs, Flat top forged pistons, polished and ported, Holley 750 Legacy, Hooker Super Comp. headers with dual Hooker Comp. exhaust and Hooker dual resonators, B&M C-6 racing tranny, with a TCI Breakaway 2600 flash stall converter, 9" rear with 2-72 gears.
Old Jan 17, 2001 | 10:38 AM
oz9609's Avatar
oz9609
C6 kickdown
No. You need the detent rod from the carb to the detent lever on the trans located at the shifter shaft.
Old Jan 17, 2001 | 10:47 AM
heavymetal's Avatar
heavymetal
C6 kickdown
OK I went out to my personal junkyard behind the garage and looked at the original, I saw a bracket connected to the shifter. Was this a manual downshift of the tranny?
If so think I will leave it disconnected. I can light the back tires up now, while passing without downshifting.
Thanks
HeavyMetal (Rod)
Old Jan 17, 2001 | 04:37 PM
stingray's Avatar
stingray
C6 kickdown
The kickdown lever only handles 2nd to 1st downshift under acceleration. The 3rd to 2nd shift under acceleration is controlled by the modulator. It is set up this way so you won't shift into second at above 60 mph when you accelerate suddenly and red-line your tach. Under normal operation shifts up are controled by the governor valve which reads driveline rpm's and changes gears in the tranny accordingly. Without the kickdown lever you may not downshif to first from a rolling takeoff in second.
Old Jan 17, 2001 | 06:31 PM
tom 400 cfi's Avatar
tom 400 cfi
C6 kickdown
FEpowerdf100
20
Jun 17, 2013 12:31 AM
AceTrucking
Apr 30, 2004 07:37 AM
heavymetal
Bronco II
Mar 10, 2001 01:35 PM
heavymetal
Jan 7, 2001 04:23 PM
heavymetal
Bronco II
Dec 24, 2000 10:12 AM
