Holley has an interactive carb sizing calculator. Follow the prompts based on your engine and it'll provide recommendations.
I went through it for your rig (with some assumptions like 5500 max RPM, about 396 cubes, and vacuum secondaries given these rigs' portly weight) and the results indicate 600 cfm would be the minimum.
You mean you would need no more than 630 , right ?I wouldn't be running my FE at 5500. It is peaked out at 3600 . FE s.come apart at high rpm . I know I have some scrap metal from what was left .
