My wife is the proud owner of a 85 Bronco II. It seems as if the engine loses its electrical power when you change to high beams or back the other woy to dims. Only loses power as long as the lever is pulled back, regains it when lever goes forward.
I am an elec. tech. and it has me scratching my head. Any help greatly appreciated.
HeavyMetal (Rod)
1977 F100 429CJ bored 30 over, Heads milled 30, edelbrock performer cam, intake, lifters, valve springs, Flat top forged pistons, polished and ported, Holley 750 Legacy, Hooker Super Comp. headers with dual Hooker Comp. exhaust and Hooker dual resonators, B&M C-6 racing tranny, with a TCI Breakaway 2600 flash stall converter, 9" rear with 2-72 gears.
I found it the ignition switch is flakey..... somehow if the switch is not in just the right spot the engine must be getting its power from the wrong contact on the switch.. I'd say thanks for the help, but there were no responses....anyway
HeavyMetal (Rod)
