Sponsored by: Innova
Grounding the head unit
Old Jul 9, 2009 | 11:16 PM
biscuit141's Avatar
biscuit141
So I just connected my pioneer wiring harness to a Metra Ford wiring harness tonight in preparation for installing a new head unit. When I hooked the grounds together I also added a second ground wire to the crimp that I can connected directly to the truck. Will this create ground loop since the head unit will be grounded through the factory harness and the additional wire I added?
Also, from what I have read the dash takes the sleeve bracket for the headunit, is this correct? (As opposed to screwing it in.)
Old Jul 10, 2009 | 01:31 AM
cartmanea's Avatar
cartmanea
The factory ground wire attaches to a ground bolt under the dash about 12" from the stereo.
Old Jul 10, 2009 | 09:36 AM
ReAX's Avatar
ReAX
You can't have too many grounds. The closer in voltage the head unit is to what any other component can get, the less voltage differential (ground loop).
A lot of apps use the cage, but you can probably go either way if your willing to make brackets.
Also, welcome to the forums.
stowbilly96
Mar 16, 2021 01:53 AM
oceantrav
Jan 2, 2017 03:44 PM
Neileo96
1997 - 2003 F150
Dec 15, 2015 10:53 AM
jrockdiddy
Jul 23, 2015 09:44 AM
betrayz
Jun 8, 2015 02:47 PM
