AirDog2 DIY Harness
AirDog2 DIY Harness
After another melted fuse I'm taking the advice of some threads and upgrading the wiring.
Some questions I have concerning the ground wires are:
Does the relay need a ground wire?
Is the relay ground for the relay switch or the AD pump?
Do I just wire the relay ground to the battery and ground the pump separately to the frame?
Also, does it matter how far from the power source the relay and fuse are? I would prefer to mount them under the vehicle away from the heat of the engine, unless that heat is negligible in a properly wired setup.
I didn't use the AD wiring harness, but I did ground the pump directly to the frame. I also ran a much larger positive wire as close to the factory pump wiring connector as I could. I used a separate relay that takes its power directly from the battery and is triggered from the factory fuel pump wires so that the pump would time out after ~30 seconds just like the factory pump.
That sounds right, but did you run a ground wire from the relay or is that not needed if the pump is grounded direct to the frame, so basically you have just 3 wires from the relay, one to the factory pump wire for turn-on, one to the battery and one to the pump?
And did you wire the relay and fuse closer to the battery or closer to the pump?
FoundOnRoadDominatin
04-20-2013 06:56 PM
hongkongrider
Bronco II
11-19-2011 09:59 PM
elfking
08-31-2010 01:35 PM
