Quick's Engine Swap Thread!
Old Aug 20, 2009 | 12:42 PM
  #76
SpringerPop's Avatar
SpringerPop
If you're swapping injectors, you might run into trouble unless you also replace the o-rings on them. They're sold as a kit.
Pop
Old Aug 20, 2009 | 01:02 PM
  #77
61 uni's Avatar
61 uni
It's beed a while, but the mechanical pump is held in place with 2 bolts I think. It is connected to a banjo fitting by either an 1 1/8 or 1 1/16 bolt(it's been a while) After you unbolt the pump, turn the crank pully with a socket which will push the pump up.
Old Aug 20, 2009 | 01:07 PM
  #78
jk_hooper's Avatar
jk_hooper
Does not HAVE to. Not sure if it makes much difference.
Old Aug 20, 2009 | 01:16 PM
  #79
strokersace's Avatar
strokersace
Originally Posted by Quick444
How much more work at we looking at to remove the bumper? I am running our of truck space to store parts! Worth the effort?
4 18mm bolts from the front and 2 15mm or 18mm (1 on each side). Then unplug your foglights as you lean it forward. It's a 5 minute job tops! It sticks up higher than your crossmember does so if you leave it on, you'll have to raise the motor up higher. I like keeping that heavy azz thing as low as possible to help with the center of gravity.
Old Aug 20, 2009 | 01:25 PM
  #80
Quick444's Avatar
Quick444
That does seem pretty easy, if I have an 18mm then I will take it off!
Old Aug 20, 2009 | 02:42 PM
  #81
CSIPSD's Avatar
CSIPSD
Actually I think I am good for right now. I bought the basic mm sockets that were mentioned previously and beyond that I will get in touch with Clay for a e new filter, mechanical fuel pump plug, intake boots, and a EGT sensor, I recall it going to 0 instantly during the boom.
Other sensors seemed to work in retrospect.
If your running Performax, if there is a problem with the EGT circit it will default to max of 1600, so you might save some money there.
Old Aug 20, 2009 | 09:32 PM
  #82
Quick444's Avatar
Quick444
It was at 0 when the truck was still running.
Old Aug 20, 2009 | 11:19 PM
  #83
Quick444's Avatar
Quick444
Do I need a torx bit to remove the fuel bowl and other things from the 01 engine? Right as the front end of the engine on the top side it looks like I might need some sort of torx bit.
Or can I go on without removing that cover?
Old Aug 20, 2009 | 11:40 PM
  #84
Quick444's Avatar
Quick444
Best way to get waterpump off?
Old Aug 21, 2009 | 12:49 AM
  #85
CSIPSD's Avatar
CSIPSD
You really should do this in a shop, with someone with experance...
Old Aug 21, 2009 | 07:53 AM
  #86
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here you go Alex. click here. Good luck.
Old Aug 21, 2009 | 08:56 AM
  #87
Kwikkordead's Avatar
Kwikkordead
I'm watching this story and really hoping it all works out.
Please be careful, there Alex.
Old Aug 21, 2009 | 09:52 AM
  #88
That_Guy's Avatar
That_Guy
I just read the whole thread (dont know how I missed it before) and I gotta give it to you Alex, you got guts. I hope everything works out for ya.
You have a link for EVERYTHING dont ya?
Old Aug 21, 2009 | 10:02 AM
  #89
miller_feed
Chris, my favorites are full of folders with links. lol. You know I have the CRS disease.
Old Aug 21, 2009 | 10:15 AM
  #90
dmueller71's Avatar
dmueller71
I wish I would've seen this days ago. So far as the TC bolts go, if you could hook the batteries back up, and have a buddie help you, you can get underneath and loosen whatever bolts you can get to, then have your friend "click" the starter to turn the engine over a bit till you get to the next one, and repeat. A little easier than trying to crank it by hand. Plus. The starter may have a little more torque to force rotation if a rod does start to bind
