Quick's Engine Swap Thread!
Old Jul 11, 2009 | 10:40 PM
husker's Avatar
husker
You might try to find a tractor with a loader or a front end loader to lift the engine if you are not on a hard surface. That would be easier to move things into place than with an engine hoist.
Old Jul 11, 2009 | 11:11 PM
Bigcat350's Avatar
Bigcat350
Originally Posted by Quick444
For now I will focus on getting a second engine, you are all right though. I will work on finding a better place for this operation.
Good move
Old Jul 12, 2009 | 12:49 AM
turboboost's Avatar
turboboost
i live in a town of around 800 with the nearest (what i call) a city of 4500 an hour and 10 mins away. you have beer buddies so i bet one has a garage, or atleast a driveway. A driveway is better then a dirt road.
Old Jul 12, 2009 | 01:50 AM
ccg711's Avatar
ccg711
got family in a town of <300 here in texas, but there is still concrete to borrow. You must be in the stix if you can't find a hard smooth surface. Borrow the local gas station lot or something. lol. May need to get inventive in your case. covering your engine will help, but only if you get the job done quick. Mine has carried on too long and my tarps are deteriorating in the sun and oil residue.
Old Jul 12, 2009 | 07:41 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The problem here is cowl clearance. I tried this once with a forklift stinger on a tractor. The stinger bent before the engine came up at all. I'm not saying that something can't be made that will hold the weight, but getting something under the cowl will really be the challenge.
Old Jul 12, 2009 | 08:56 AM
beanhead6D5's Avatar
beanhead6D5
When you are looking for a place to get under roof.See if there is a local mechanic that has a service truck with a boom hoist on it.That could help you out with the engine R&R.
If you can get a 4'x8' piece of 3/4" plywood(maybe two sheets) it will make a floor for the hoist to roll on.
A few bags of floordry will help keep fluids from running all over the place.
A portable air comp.and air tools would be nice to have also.
Old Jul 12, 2009 | 05:32 PM
jk_hooper's Avatar
jk_hooper
Dont forget the fuel line tools. Thise things can be a booger.
Old Jul 12, 2009 | 09:10 PM
Quick444's Avatar
Quick444
Everyone should Google Talkeetna, Alaska before doubting that I am in the middle of no where. Most of the cabin's around here don't have concrete driveways, water and electricity are absolute luxuries too. And to be clear all of my friends are also people who are just in the town for the summer jobs, so we are all homeless.
Thank you for the continued advice on tools needed and ways of doing things. I am going to try and find a cement spot where I could get the engine swap done and then move the truck elsewhere until I patch up all the little things that go wrong on a project of this size.
Sounds like I need a torque wrench, fuel line tool, and some basic socket sizes.
Old Jul 12, 2009 | 09:26 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
or put up a for sale sign on the side of the truck and 100' before it, maybe someone will offer you more for it than the trouble it's worth
Old Jul 12, 2009 | 09:52 PM
jk_hooper's Avatar
jk_hooper
A pry bar also seems to be handy.
Rolling the truck might be easier.
Old Jul 12, 2009 | 09:59 PM
farmdad's Avatar
farmdad
Would it be possible to have the truck hauled to a more user-friendly, location? I know that it would cost a few dollars but a more workable location would make the job a lot easier, faster and possibly safer. Or can't you get there from here?
Old Jul 12, 2009 | 10:09 PM
ChunderDownUnder's Avatar
ChunderDownUnder
If you do it gets some pics bro. Im dying to see how this un folds. good luck m8
Old Jul 12, 2009 | 11:43 PM
  #28
ccg711's Avatar
ccg711
Ok I believe him. Just looked at google maps satellite imagery and he's boned for a surface, unless you can borrow something at the airport there. Weird. In Texas not all the rural strips are paved but the roads are (except for rural county roads). I get the impression Alaska is just a little bit different. Doesn't even look like the businesses or streets are paved, Just the airport and main road. I used bags of cold patch asphault to make a surface for my job. But if you don't have a place to call home that's probably no gonna work. Maybe you could borrow some airport surface or hangar space. Just invest in deep and shallow metric size wrenches. Only a few sizes for the most part. Some things may require an occasional twelve point. Don't forget the combinations and some woble joints as well as extensions. It will be a snap for the most part in regards to tools. Get the metal disconnect tools for the fuel lines. I used plastic ones and just about invented a few new curse words. Lots of brake cleaner would probably come in handy too.
Chad
Old Jul 13, 2009 | 08:41 AM
  #29
Quick444's Avatar
Quick444
Chad
Thank you for your reply. I was trying to reflect on possible places and the train depot came up as a possibility. Its hardly more than a shack that is used from 10am to 12 noon and then again from 3pm to 6pm. If I could get going on it after 9pm and get engine in before early I think I would be ok. I am sure I could have a friend tug the truck over there so I could use the parking lot for just the main swap.
If nothing else, I will work on buying the engine this next Saturday, as well as getting the current engine drained and prepped to be pulled. Ill put the coolant in 1 gallon water jugs, remove the down pipe and turbo, pull out the batteries and intake accessories and anything else I can remove without making it clear to the outside world that anything unusual is about to happen.
Old Jul 13, 2009 | 08:45 AM
  #30
Quick444's Avatar
Quick444
Thought about it. Not sure yet.
I don't really have a more user friendly location. Then if I did find a place, I would have to figure out how to get to and from there.
