Quick's Engine Swap Thread!
Old Oct 11, 2009 | 12:56 PM
  #136
dmueller71's Avatar
dmueller71
I have no answer to your question, but I was actually just thinking about you. Being in Illinois and it's 32 degrees, I was hoping that you were done with this project, and just out having too much "job well done" fun and didn't have time to update us. Sounds like you're getting close though. We're all still pulling for you
Old Oct 11, 2009 | 06:42 PM
  #137
farmdad's Avatar
farmdad
Crankshaft vibration dampener bolt 212 ft/lbs
HPOP drive gear mounting bolt 95 ft/lbs
Old Oct 11, 2009 | 06:44 PM
  #138
farmdad's Avatar
farmdad
Double post
Old Oct 13, 2009 | 02:46 AM
  #139
Quick444's Avatar
Quick444
Thanks Mark.
Old Oct 13, 2009 | 05:04 AM
  #140
makomaker's Avatar
makomaker
Alex, after you get your truck running, you have my perission to go to Nagley's store and West Rib Pub and have a vey cold beer.
drink one for me too.
Old Oct 13, 2009 | 05:09 AM
  #141
makomaker's Avatar
makomaker
And it looks like your weather window is good for a few days...sunny to partly cloudy with highs in the 50's. Go Alex, pullin' for you
Old Oct 14, 2009 | 12:09 AM
  #142
Quick444's Avatar
Quick444
Thanks Jay. Trust me however, I have been drinking plenty O' beer.
After two summers here you sort of get to know all the bar and pud tenders. I helped pay off any mortgages the Fairview may have had this summer.
Old Oct 14, 2009 | 09:17 AM
  #143
farmdad's Avatar
farmdad
Come on, Alex, the suspense is getting intense. How goes it?
Old Oct 14, 2009 | 11:27 AM
  #144
dmueller71's Avatar
dmueller71
Man dude, you gotta be getting close
Old Oct 14, 2009 | 02:38 PM
  #145
Quick444's Avatar
Quick444
Got her fired up again last night. She runs but she's a little cranky which is understandable.
Unfortunately I have several issues to iron out.
Glow plugs aren't working.
I have pin hole leak where the oil pan meets the rear of the engine. Only leaks once the oil gets nice and hot.
Coolant system seems to be acting up and the upper hose never heats up. Thinking my thermostat might be fubar.
A very odd rattle/vibration that comes and goes.
I have to work the next 15 days so I don't quite know when I will get around to this.
Old Oct 14, 2009 | 06:48 PM
  #146
parkland's Avatar
parkland
About the coolant:
(I learned this all the wrong way)
I changed my coolant once, drained it all, flushed with garden hose water, and put the plug back in and started filling.
I noticed that it wasnt all going in, thought maybe needs to warm up. Luckily I drove to my friends shop, where he showed me how slowly it needs to be added or it will airlock. Lucky I didnt overheat and blow something.
About the upper hose heating up;
First, it takes a bit of driving before any cooling goes on.
Second, is that the return line guys? if it is, it might always seem cool. ?
Old Oct 15, 2009 | 04:44 AM
  #147
Quick444's Avatar
Quick444
I think I almost learned this lesson the tough way. What is the proper way to fill it up? I had the reservoir slowly filling up the other day but I suspect I didn't leave the top off long enough and burp the system out.
I drove around for about 5 miles when I realized that I didn't have any hot air which meant the heater core wasn't getting water. Slowly bled some pressure from the reservoir top, the coolant system made a ton of burbling and then I had hot air when driving. However a mile later I noticed the upper hose was quite bloated and obviously not circulating.
Originally Posted by parkland
About the coolant:
Old Oct 15, 2009 | 08:06 AM
  #148
Kwikkordead's Avatar
Kwikkordead
Congrats on getting it running!
Get a long stem thermostat and replace the one that you have in there.
I had no trouble at all when I changed mine out, just pour in the coolant and run it.
Heater worked great the first time through.
Old Oct 15, 2009 | 07:49 PM
  #149
parkland's Avatar
parkland
just try pouring it REALLY slow, and if it wont go, worst case scenario try draining it again and pouring really slow next time.
Old Nov 3, 2009 | 11:12 AM
  #150
dmueller71's Avatar
dmueller71
So how goes the project? Have you been working out your issues??
