Cruise control not working...
Old Apr 27, 2013 | 06:38 PM
  #46
husky390's Avatar
husky390
Thanks, so basically I need to start with the module and make sure that is not frozen? Also, would the reverse lights not working have anything to do with the cruise not working?
Old Apr 27, 2013 | 10:27 PM
  #47
DALEDIESEL's Avatar
DALEDIESEL
Speed control
Wait a second, if your truck is a 1990 you don't have the module! You have the vacuum/electric type. Sorry! Dale
Old Apr 27, 2013 | 10:51 PM
  #48
subford's Avatar
subford
He still has a module under the dash but it does not look like what he is thinking above.
Old Jun 13, 2015 | 01:16 PM
  #49
JSavens's Avatar
JSavens
Clock Spring
[QUOTE=redlightning93;7699388]Does your horn blow?
If not it sounds like a Clock Spring.
Does it also affect cruise control and make your airbag light activate? Only a great relationship with a mechanic kept my truck i inspection current. I didn't tell him and he didn't ask! That's a great relationship! He knows I'll fix it.
Old Sep 14, 2015 | 04:30 PM
  #50
jim&i's Avatar
jim&i
cruise control not working and can not get into gear after starting
hey master minds this one has got me stumped! have a 2002 f250 4x4 . number 34 fuse (10amp) blows when replaced. cruise stopped working and can not get into gear from park after starting but turn ignition swtch to 1 click forward and put into nuetral then start and go on about my business? cruise recall completed in 06, brake lights work horn works/ any help on this would be great.
Old Sep 14, 2015 | 05:41 PM
  #51
rla2005's Avatar
rla2005
Try posting in the correct forum: Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
Old Sep 14, 2015 | 07:11 PM
  #52
mrollings53's Avatar
mrollings53
You've got a short to ground on whatever that fuse controls.
Old Jan 27, 2018 | 02:31 PM
  #53
ragtop69's Avatar
ragtop69
My '95 Bronco cruise control doesn't work. I've checked the relevant fuses in both boxes and performed the shut off switch replacement. Had the top off the servo and it moves smoothly without any binding. There was power indicated at the plug to the servo. My brake lights work and my horn works. I understand there is a cruise control relay. Where would I find that? Also, despite moving the big gear on the servo manually, I didn't see any movement at the throttle body. Could the cable be broken or bound? If so, how would the servo mechanism be able to move?
Two further questions: 1) Does a '95 Bronco have a dash light to indicate that the cruise control is on? Where would that be located and, for the record, if it does have one mine isn't working. 2) I found a video on cleaning the steering wheel switches with electrical cleaner, but the featured Ford vehicle was a later model. Can the steering wheel buttons be removed from the switches to permit access with a cleaning solution?
Old Jan 31, 2018 | 09:40 PM
  #54
Trail_Rider's Avatar
Trail_Rider
What has the horn got to do with anything? My horn has never worked and until recently the cruise worked just fine.
Old Feb 4, 2018 | 01:51 PM
  #55
jason90f150's Avatar
jason90f150
For some reason my speed controll only works when I get a brake light when I apply the parking brake. Sometimes it works sometimes it doesnt. If I wiggle the parking break pedal it'll come on then my cruise control will work. If it doesnt light up cruise doesnt work
Orlie
Feb 27, 2023 09:32 AM
blue66tang95f150
Aug 14, 2017 08:17 AM
1997Aerostar
Aerostar
Apr 30, 2017 08:41 PM
svastano
Apr 27, 2017 09:12 PM
Larboy
General Diesel Discussion
Mar 2, 2017 01:17 AM
