Aerostar Ford Aerostar
No Cruise Control
Old Apr 13, 2017 | 12:33 PM
1997Aerostar's Avatar
1997Aerostar
No Cruise Control
My 1997 Aerostar's cruise control is not working. Horn is functional however. I've checked fuses and they seem to be ok. What could my problem be?
Old Apr 13, 2017 | 12:50 PM
don-ohio's Avatar
don-ohio
Did you check the actuator cable on the throttle? I lost my cruise and horn a while back and it was the clock spring under the steering wheel. Works fine now. don-ohio (:^)
Old Apr 13, 2017 | 12:54 PM
1997Aerostar
No. I will tomorrow. No time to today.
Old Apr 13, 2017 | 01:01 PM
don-ohio's Avatar
don-ohio
I know that feeling! I'm heading out to pull an engine with the backhoe here shortly,for my neighbor. don-ohio (:^)
Old Apr 13, 2017 | 05:17 PM
zenish's Avatar
zenish
check the vaccum hoses under the hood.
Old Apr 13, 2017 | 08:18 PM
xlt4wd90's Avatar
xlt4wd90
Also check the switches on the brake pedal for the brake lights, and possibly a separate one for the cruise control.
Old Apr 14, 2017 | 11:59 AM
93nighthawk's Avatar
93nighthawk
97 is electronic, not vacuum controlled, I would make sure that the cable did not clip off the throttle body. Mine does that every once in a while, not the best design.
Old Apr 17, 2017 | 07:35 PM
1997Aerostar
It is connected and the cable is not cut in any way. Checked all of my fuses and replaced one that went bad. Still no cruise
Old Apr 24, 2017 | 03:35 AM
Jose A.'s Avatar
Jose A.
could be the ON or the SET Switch at the steering wheel. They do lose contact, take it to over 45 mph and start pressing the ON and SET switch repeatedly to see if you get any response.
Old Apr 25, 2017 | 08:14 PM
1997Aerostar
I tried today but failed to get a reading. I'll just have to take it in to get looked at.
Old Apr 30, 2017 | 08:41 PM
KhanTyranitar's Avatar
KhanTyranitar
There are several fault codes, including ABS codes, that will disable cruise control. Some of these codes may not trigger a CEL, but will still lock out cruise control.
That aside, one of the common problems is a broken clock spring in the wheel.
njstevens
Oct 1, 2021 09:41 PM
bossgobbler
May 10, 2012 10:30 PM
IMPRTKLLRZ28
Dec 7, 2010 10:55 PM
1988midnightblue
Jun 22, 2007 07:24 AM
Ted Church
Aerostar
Sep 1, 2003 04:31 PM
