Heater core?
Old Jun 30, 2009 | 09:04 AM
Cougar Hunter's Avatar
Cougar Hunter
Heater core?
2000 Navigator.
Alright, I smell a coolant leak... can't see it coming from anywhere and it isn't leaking inside the cab. The guy I bought it from said it's the heater core so I'm going to start there. However, the haynes manual & google aren't giving me ANY clear directions whatsoever where the heater core exactly is or what has to be removed to get to it?
Does the entire dash need to come out or what?
Thanks.
Old Jul 1, 2009 | 07:07 AM
Johnny Langton's Avatar
Johnny Langton
Thanks.
Yes.
It's a 6-18 hour job depending on your mechanical abilities.
JL
Old Jul 1, 2009 | 10:18 AM
Cougar Hunter
Thanks.
But dammit... 18 hours it is...
Old Jul 13, 2009 | 09:25 PM
Cougar Hunter
Alright... got the heater core replaced. The two hoses connecting to it were a PAIN and just did not want to go on. Everything gets back together... one busts loose and coolant is draining out... Those hoses just don't want to "catch".
Hopefully we can get to them through the engine bay without the dash coming back out...
Just curious, has anyone converted over to a standard rubber hose with standard clamps? I'm thinking about doing this, and maybe even just bypassing the rear heater core. Does anyone see any problems with this or have any suggestions?
Old Jul 14, 2009 | 06:43 AM
Johnny Langton
You probably broke an ear off of the nylon retainer clip. You can convert to conventional clamps,but it's gonna be difficult to get in there to tighten them and make sure that they're sealing well.
JL
Old Jul 14, 2009 | 07:13 AM
Cougar Hunter
I'll order new clips and o-rings today from ford... anything else I should get along with those 2?
Old Jul 14, 2009 | 07:15 AM
Johnny Langton
Grab a small tube of dielectric grease to lube the hoses and o-rings for reassembly. It's cheap,and makes it much easier to push the hoses onto the tubing.
JL
Old Jul 14, 2009 | 07:28 AM
Cougar Hunter
Will do, thanks.
Also in case anyone finds this thread in a search, I found a word document a guy on here put together. 97F150 was his name I believe... just trying to give credit as I did not put this file together. Search for the document.
wisdum
34
Jun 8, 2022 03:05 AM
treverd
Mar 30, 2016 09:31 PM
wilit
29
Nov 2, 2015 03:45 PM
brimis
Sep 24, 2013 01:09 PM
Voksboy
May 10, 2004 03:45 AM
