Sponsored by: Auxito
Fluid Capacity
Old Jun 29, 2009 | 06:53 PM
wlittle's Avatar
wlittle
Fluid Capacity
My truck has 254000 kms on it and am need of a full fluid change. I have only had the truck for 20,000 but want to change everything so that I have a maintenance record to start from. I don't have any info on any capacities, so was wondering if any one had the capacities, and which fluids I should use. I want to do front/rear diff's, transmission - 4r100 - 4r70w, transfer case. Thanks for your help.
Old Jun 29, 2009 | 07:48 PM
Ron W.'s Avatar
Ron W.
http://www.fcsdchemicalsandlubricant...r/quickref.asp
Here's a link but in some cases you're better off taking to a shop.
Old Jun 29, 2009 | 08:54 PM
steve(ill)'s Avatar
steve(ill)
trans takes about 13 quarts for MERCON V. You can put that in the transfer case also. I think it holds couple quarts. Axles take less than 3 quarts each. Rear should be full synthetic 75w140, front can be 80-90 standard lube. what year, size?
Old Jun 29, 2009 | 10:50 PM
wlittle's Avatar
wlittle
2002 Supercrew, 5.4, auto, 4x4. Thanks for the info.
Old Jun 30, 2009 | 06:18 AM
shorebird's Avatar
shorebird
Go to ; http://www.motorcraftservice.com/pub.../02f12og4e.pdf
Page 285 has the fluid capacities.
onuredneck707
Mar 30, 2011 05:09 PM
jstans
Mar 4, 2009 08:14 AM
Bowie
Nov 23, 2008 08:36 AM
heathrunkles
Feb 23, 2008 01:14 PM
woodly1069
Jan 24, 2008 06:31 PM
