1978 - 1996 Big Bronco
Diesel Bronco
Old Jun 10, 2010 | 08:14 AM
  #46
chrlsful's Avatar
chrlsful
then what do you do? "Medium block"?
"W" block. Look @ it w/o the intake n from the end (frnt or back), looks like a W.
Old Jun 10, 2010 | 09:01 AM
  #47
American Thunder's Avatar
American Thunder
All joking aside, the 351M and 400 are simply Modified small blocks. That's why the M is there.
Old Jul 24, 2010 | 10:11 AM
  #48
moose0211's Avatar
moose0211
Woops.. double post and I dont know how to delete it. Sorry
Old Jul 24, 2010 | 10:12 AM
  #49
moose0211's Avatar
moose0211
I am running a stock 351 Clevland 2v in my 72 Gran Torino and it is one of the most powerful cars I have ever driven. If I hit the gas too hard, the car will spin out. I love my Cleveland. Anyway, old post but I want to do a IDI swap in a 78 or 79 Bronco too. So I can buy a cheap donor with a good engine and transmission and swap the drivetrain to the Bronco, right?If this is the case I can do it for under 2,000 dollars as cheap as trucks are up here. A few questions though, will the motor mounts out of a donor truck work for the Bronco? I also heard, I think from a post by American Thunder, that I should do a 3 inch body lift and move the engine back a few inches, is this true? I am hoping to pull this off with a stick welder and some basic tools, would there be anything else I would need?
Old Jul 24, 2010 | 02:41 PM
  #50
chrlsful's Avatar
chrlsful
351's in the Baja PreRunners ('66-'77 Broncos)! Have fun moose r .
Old Jul 24, 2010 | 04:38 PM
  #51
American Thunder
I have the whole build-up detailed with pics in my '78 Bronco thread, check it out. But I used a Cummins, which required custom trans adapter and flexplate. The body lift makes things a LOT easier. And moving the drivetrain back in the chassis has some important benefits, but also causes some issues that must be resolved.
warriorprophet8
Bronco II
18
Dec 11, 2019 08:01 AM
Diesel_Brad
1966 - 1977 Early Broncos
Feb 13, 2015 12:50 PM
Dirtboy953b
Dec 1, 2014 08:17 AM
ola1234
23
Nov 22, 2014 08:26 PM
larryejoh
Aug 22, 2011 06:59 AM
