1978 - 1996 Big Bronco
Bronco with original diesel?
Old 10-21-2014, 12:40 AM
ola1234's Avatar
ola1234
ola1234 is offline
Hey!
Found one on craigslist who says his Bronco is delivered new from Ford equipped with a diesel. Could that be right?
This is what the add says: "SUPER RARE! 1983 FORD Bronco 4x4 w/Factory Diesel *
Extremely RARE! 1 of Only 47 built in 83! "
If so; what kind of dieselengine would it be in it?
Old 10-21-2014, 07:48 AM
jas88's Avatar
jas88
jas88 is online now
No such a thing as a Bronco with factory diesel.
Old 10-21-2014, 09:00 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
in a different country that could be possible. not state side though
Old 10-22-2014, 04:28 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Ask for a VIN and check it out, but as far as the US there is no knowledge of a factory diesel Bronco.
Old 10-22-2014, 10:39 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Can you post a link to the add? Or pictures?
Old 10-23-2014, 09:15 AM
jas88's Avatar
jas88
jas88 is online now
It was on Seattle CL but it is gone now.
Old 10-24-2014, 03:47 PM
ola1234's Avatar
ola1234
ola1234 is offline
Here it is again
Looks damn original to me!
Probably shouldn`t put it on here if I want to get it to Norway. But just had to share it. Anyone on here living close to it to check it out for me? The mechanical stuff can always be fixed, but rust worries me. Too bad to use 3000 us dollars in freight for a shipload of rust
Old 10-24-2014, 09:52 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
Old 10-25-2014, 01:12 AM
1985 Bronco
I'll bet that the engine was swapped awhile ago, the gauge cluster has been swapped, it has the newer style wood grain, and the gauges were black from the factory, not white. Carpet doesn't look factory, and you can see the new radio and speakers. There's also that aftermarket front bumper. It's still a cool truck, and I'd buy it, I don't think it's original though.
Old 10-25-2014, 01:25 AM
1985 Bronco
BTW, to answer your original question, it would have a 6.9 idi
Old 10-25-2014, 02:31 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i like diesel broncos
Old 10-25-2014, 02:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1983: FoMoCo introduced the 6.9L diesel that was made by Navistar, it was only available in E/F250/350's.
No Bronco sold new in the US/Canada of any year was available with a diesel. 1983 Bronco's were available with 300 (4.9L) I-6, 302 (5.0L) and 351W (5.8L) ONLY.
Old 10-25-2014, 02:42 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i got a 6.9 in my 78 bronco but thats not original.
Old 10-25-2014, 12:29 PM
Thunderhorn's Avatar
Thunderhorn
Thunderhorn is offline
I've always wanted to swap in a diesel but recently I went looking up specs and just the weight of these engines is alarming. Any one you could choose is going to add an extra 400-500 pounds directly to the front. How does your bronco handle on and off road skip? And would it be correct to assume you've swapped out stronger axles and suspension?
Old 10-25-2014, 09:42 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
my bronco isnt a road vehicle, its offroad only. but the diesel i put in the 75 crewcab handles just fine. not that much heavier but can pull around 20mpg.
Quick Reply: Bronco with original diesel?
