1966 - 1977 Early Broncos
Dana 44 value
Old Jan 21, 2015 | 05:04 PM
Diesel_Brad's Avatar
Diesel_Brad
Dana 44 value
What is the going rate for the Dana 44 from an early bronco?
Drum brake
Old Jan 21, 2015 | 08:58 PM
dclack's Avatar
dclack
Around here, probably $400-$500, but our prices always seem to be higher than back East.
Old Jan 22, 2015 | 08:31 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is a ball park for a loaded pair....wow Ford Bronco Parts
Or.. Dana 44 Front Axle Housing-Price Reduced!
Early bronco disc brake Dana 44
Old Jan 22, 2015 | 04:00 PM
Diesel_Brad
Ok thanks guys. Thought they were worth more, but I guess not
Old Jan 22, 2015 | 04:13 PM
dclack's Avatar
dclack
The Bronco D44 is really only valuble to those who think the D30 is too weak. But a lot of them swap to a either a full width D44 or D60. Some will cut a full with D44 down to EB size since they are a high pinion.
Old Feb 10, 2015 | 07:14 PM
shadetreebronco's Avatar
shadetreebronco
The 76 - 77 Bronco Dana 44 may have disc brakes already but you are limited on what wheels you could use , and tie rods/steering set ups.
I would rather use a drum brake dana 44 and swap in F150 disc knuckles.
Old Feb 13, 2015 | 11:53 AM
chrlsful's Avatar
chrlsful
Fella wants to sell me 1 for $100.
Anywhere to get the process on cutting it down for the EB?
I will have a 250/4.1 Lt motor in (Maverick mounts 'sloted') so it will B lower in the frame than current 170/2.8 Lt. Think it will bit the HP d44 w/1" BL and 2" SL?
Thanks.
Old Feb 13, 2015 | 12:50 PM
dclack's Avatar
dclack
Here's few different methods:
Narrowing A Dana 44 Axle Assembly
Narrowing a HP Dana 44 for an Early Bronco
I don't know if it will hit with your setup, but a HP will usually cause clearance issues with oil pan and exhaust on stock rigs.
crescentwrencher
45
Feb 23, 2008 05:19 PM
bigbubba87
Offroad & 4x4
28
Sep 15, 2007 08:53 AM
Cheshire Cat
15
Feb 19, 2004 04:18 AM
nola50
1978 - 1996 Big Bronco
Jan 8, 2002 10:30 PM
