english translation?
Old Jun 24, 2009 | 09:53 PM
catman52987's Avatar
catman52987
0470 EBP Exhst press sensor ckt malfnct (96 MY) No-start or crank mode Biased sensor, open signal return
Old Jun 25, 2009 | 08:11 AM
rideracelivemx7's Avatar
rideracelivemx7
well i dont htink any of the gurus are on right now but ill give a wak at it, so is it just cranking and no start or no juice at all? i didnt think a exhaust pressure sensor would cuase a no start, if you want to replace it i belive its just right behind the hpop resivour, its a round pice, tan i think, you can miss it, its litterally inches from the top of the res.
Old Jun 25, 2009 | 08:51 AM
catman52987
it pulled three codes ... two were cps codes ... which i have already replaced ... and that one up there the 0470 was the other code which it is pulling ... i cleared the codes ... unpluged the scanner .. turned the ignition on then off .... plugged it back in and it pulled it again.... i dont know what the world it means... i hope someone here does
Old Jun 25, 2009 | 12:27 PM
Cuda_jim's Avatar
Cuda_jim
EBP Exhaust Back Pressure sensor wireing or the sensor is bad.
Here's an introduction and a 'how to' in a .pdf format:
Old Jun 25, 2009 | 01:31 PM
catman52987
thanks for the pdf files jim!!! would it kick this code if the EBP was unplugged?
Old Jun 25, 2009 | 01:44 PM
Brown Falcon's Avatar
Brown Falcon
I have had my EBPV unplugged for a couple months and never got a code from it. It just keeps it open all the time.
Old Jun 25, 2009 | 04:07 PM
Cuda_jim's Avatar
Cuda_jim
If you unplug the EBP sensor it will throw a code. You can unplug the EBR (Exhaust Back Pressure Regulator) though with no CEL like brownfalcon said above. The EBR is a 1 wire connector located under the turbo housing. The EBP sensor has a 2 wire connector and is located on the right side, front of engine behind the HPOP.
Old Jun 25, 2009 | 05:40 PM
BlueMule's Avatar
BlueMule
Yep, I've been getting that code ever since I threw away the sensor and tube and plugged the hole in the manifold.
BLACKHAWK_1989
17
Apr 8, 2015 03:07 PM
mudslinging79
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 21, 2010 09:27 PM
b69bama69
1983 - 2012 Ranger & B-Series
Jan 6, 2007 08:05 AM
silly34
May 15, 2005 08:38 PM
Slider28
Bronco II
Mar 23, 2002 06:55 PM
