Bronco II Ford Bronco II
2.9l 86 B2 Throttle position sensor test.
Old Mar 13, 2002 | 04:39 PM
Slider28's Avatar
Slider28
Old Mar 14, 2002 | 11:26 AM
Slider28's Avatar
Slider28
i got reading of .87 throttle closed and at WOT i have 4.87...
is that good??? Is that why im sinking so much money into my baby bronco??
chaz.
Old Mar 14, 2002 | 12:30 PM
400m's Avatar
400m
Those numbers are for K-ohms right? Well if they are I think your TPS sensor is alright again I can't remember the exact numbers but the fact that there is a large increase in resistance from closed to WOT means that it is working and I think the range is correct but I would trace the wires back to the computer and test the numbers back there to make sure there are no wire problems from the TPS sensor to the computer.
400m
Old Mar 14, 2002 | 12:43 PM
Slider28's Avatar
Slider28
Those are volts... sorry.
chaz.
Old Mar 17, 2002 | 05:09 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Chaz, that is a perfect test reading for the TPS voltage. It's OK.
I can't answer your other question, sorry......:-X23
Old Mar 18, 2002 | 08:59 AM
Slider28's Avatar
Slider28
Thanks For your help helps save me a buck or two. ( No Pun intended) heh
chaz.
Old Mar 23, 2002 | 06:55 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck
I had one that would jump all over the place right around the cruise position. It should change resistance evenly as you rotate it through it's range, if it jumps to infinity or goes high-replace. Best to do this with an ohmeter.
Mcnugget
Testing.....
Jul 19, 2017 04:41 PM
Tombonetoo
Testing.....
Feb 20, 2017 04:03 PM
mudslinging79
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 21, 2010 09:27 PM
tom3tone
1983 - 2012 Ranger & B-Series
May 25, 2007 02:00 AM
PAUL_2
Dec 29, 2000 02:34 PM
