General Automotive Discussion
No O/D and Drive
Old Jun 21, 2009 | 11:16 AM
cletus88's Avatar
cletus88
Question No O/D and Drive
Hello, I am new to the club and have a question for the group. I have had several ford explorers and have never had this issue. I have no drive or o/d. when I reset the system (by removing battery cables) everything is fine until I turn off the engine and try to start again. It shows up that O/D is off and I have no drive. Is this the solenoid or something else?? I am hoping this is something I can fix myself. I usually do all the repairs on my trucks. but, have not run into this issue before. Any input would be greatly appreciated
Thanks, Mike from Ohio
Old Jun 21, 2009 | 02:58 PM
Monsta's Avatar
Monsta
Sit. Stay.
Mike,
Can you post the specifics about your truck like the model, year, engine, miles, 2 or 4 wheel drive, etc. etc.?
Old Jun 21, 2009 | 05:58 PM
cletus88's Avatar
cletus88
Sorry bout that. I have a 95 explorer eddie bauer edition. 4wd. 4.0 with a v-6
Mike
also it has about 220k on it
Old Jun 25, 2009 | 04:49 AM
Monsta's Avatar
Monsta
Sit. Stay.
To the top...
I know nothing about those trucklets. Maybe posting in the Explorer forum would get you better help?
But when you say "drive", do you mean that it will not move when in Drive but will if you place the selector in any of the other forward position and reverse?
Old Jun 25, 2009 | 08:48 AM
cletus88's Avatar
cletus88
It will go into drive (o/d light flashing) when I get up to speed the engine will wind out like the trany is slippin. but, when I take the battery cables off and reset system it runs fine until I shut off again. Thanks for the help. I will post in the other forum too.
Mike
Old Jun 25, 2009 | 12:59 PM
Lazy K's Avatar
Lazy K
The flashing light means that the computer has stored a trouble code.
I would get the codes read, may pinpoint the fault.
Old Jun 25, 2009 | 04:10 PM
Deluxe05's Avatar
Deluxe05
I wholeheartedly agree with Lazy K. Get the codes. Many auto stores will do this for free.
This is just an educated guess, but it sounds like either the PCM or TCM is not quite right. It is either storing or not overwriting some bad parameters that it is "learning", and the "reboot" (disconnecting the battery) is forcing it to go back to what is written in the firmware. The O/D light flashing tends to make me think it is the TCM (but that is no guarantee).
Old Jun 25, 2009 | 04:57 PM
Greywolf's Avatar
Greywolf
Check the PCM connector and see if it has gotten loose somehow. A whole lot of tranny issues are connector based. The flashing light is a PCM fail indicator usually. It may be a torn wire up front or a bad solenoid connector at the tranny or transaxle. Tranny in this case.
Old Jun 26, 2009 | 12:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't think so. The PCM (there is no TCM in these trucks) has detected a problem. That made the OD light flash, stored a code to tell the tech what's wrong, and put the trans into failure effects management mode, which is why some of the gears are not available. The PCM has determined that the trans either can't shift to those gears or will cause more damage if it tries to. So the solution is to not command a shift to those gears.
Disconnecting the battery erases the codes so the PCM doesn't know that anything is wrong until it runs enough tests to start over with the codes. Until then it will command all the gears, even if that causes much more expen$ive damage.
Get the codes read before disconnecting the battery.
Old Jun 26, 2009 | 10:13 PM
Greywolf's Avatar
Greywolf
That's a good point - but how does the PCM detect it?
I still think it's a connectivety problem
I guess the codes will provide clues.
Old Jun 27, 2009 | 05:04 AM
Mark Kovalsky
There are many different tests that the PCM uses to detect problems. It can check the electrical circuits. It can check that the speed sensors are reading when the should be. It can check that the gear ratio across the trans is what it should be. If any of these, and a few others, are not right a code is stored.
It could be a connectivity problem, it might not be. It's impossible to say without the codes and some diagnostics.
Old Jun 27, 2009 | 09:53 PM
cletus88's Avatar
cletus88
Thanks everyone for all the info. I am going to be checking all of this and a few other things and will let you guys know the outcome.
Mike in Ohio
Old Jun 28, 2009 | 07:49 AM
mbogosia's Avatar
mbogosia
My OD light was blinking and by the time I noticed it my transmission was cooked. $2400 later and I am back on the road.
b19gale
New Member Introductions
Jul 30, 2013 05:28 PM
FuzzEMoto
Mar 6, 2012 12:56 PM
eatont9999
Aug 14, 2011 09:57 AM
edmundo7
2004 - 2008 F150
Feb 12, 2008 09:23 AM
Niceguyeddie69
2004 - 2008 F150
27
Aug 4, 2007 10:37 PM
