The O/D button....
Old Feb 7, 2008 | 11:02 AM
edmundo7's Avatar
edmundo7
The O/D button....
I was reading the maunal but its not very clear.
Is the O/D button for off road gigs? or for city driving?
Thanks
Old Feb 7, 2008 | 11:14 AM
MBBFord's Avatar
MBBFord
It is mostly used for towing heavy loads so it stays out of OD, and doesn't hunt between gears(which is bad for trannys).
marobrown's Avatar
marobrown
most of the time it is used when you are pulling a trailer. I usually leave mine on when pulling my pop up, but something heavier I will if the truck seems to be shifting in and out of overdrive alot.
Old Feb 7, 2008 | 12:40 PM
Deluxe05's Avatar
Deluxe05
Page 274 of the 2008 F150 Owner Manual:
Drive is activated when the transmission control switch is pressed.
  • This position allows for all forward gears except overdrive.
  • O/D OFF lamp is illuminated.
  • Provides engine braking.
  • Use when driving conditions cause excessive shifting from O/D to other gears. Examples: city traffic, hilly terrain, heavy loads, trailer towing and when engine braking is required.
  • To return to O/D (Overdrive), press the transmission control switch. The O/D OFF lamp will not be illuminated.
  • O/D (Overdrive) is automatically returned each time the key is turned off.
As has already been stated, the transmission will generate a lot of additional heat & see premature wear if it is continuously shifting between gears (a.k.a. hunting or seeking).
So, turn the overdrive off if:
  • the transmission starts boucing between gears
  • many situations wherein the clutch fan continuously engages
  • descending steep grades where the brakes may begin to overheat from excessive usage
  • and, anytime you are doing some heavy towing or hauling
Old Feb 11, 2008 | 05:27 PM
LACityFD's Avatar
LACityFD
Even when not towing, I like to turn O/D off when decelerating down grades or when approaching off ramps. The 5.4 provides some good engine braking.
Old Feb 12, 2008 | 09:23 AM
Twinsdad98's Avatar
Twinsdad98
What every one has already stated. Good for engine braking on steep grades and if you're tranny is shifting in and out of overdrive, turn it off so it'll stay in one gear.
dvblair
2004 - 2008 F150
Jun 1, 2013 09:35 PM
creator
Jun 26, 2012 08:12 AM
frkncrazy
1983 - 2012 Ranger & B-Series
15
Dec 3, 2004 08:15 AM
Redbone
1997 - 2003 F150
Mar 21, 2002 06:43 AM
