Sponsored by: Real Truck
Brake issues, help please
Old Jun 20, 2009 | 08:28 PM
9900imatt's Avatar
9900imatt
hi there, i have a 2006 f-250 5.4, single rear wheel, about a year ago, had a problem where the passenger side rear caliper seized up, it was replaced under warranty, about 6 months later, the other side did the same and was also replaced under warranty, about 6 weeks after that the ohter side did the same thing again, i payed for that one and replaced the rubber line goin to the caliper, now about 2 months later the other side is acting up again, i'm at wits end in this thing, could the master cylinder be bad, maybe the booster or that electric thingy , any help would be appreciated, thanks
Old Jun 20, 2009 | 08:37 PM
ReAX's Avatar
ReAX
What was the cause of the caliper failure?
saturated brake fluid would cause more corrosion, but I can't think of the MC directly causing the caliper to break.
Old Jun 20, 2009 | 08:47 PM
9900imatt's Avatar
9900imatt
i really dont know what the cause of failure was, i didnt do the first two, just the last one, and it got so hot it melted the rubber around the pistons on the caliper
Old Jun 21, 2009 | 12:04 AM
pjwoolw's Avatar
pjwoolw
It might not be a caliper issue. The pins that the caliper rides on are sticking. At least that was the trouble with mine.
Old Jun 21, 2009 | 12:11 AM
whits's Avatar
whits
Yes, replace all the pins and boots. if they got hot before the boots probably cracked leading to the pins seizing. you can get a kit at most parts houses cheap with boots and pins. don't forget to clean out the slide pin holes good to, then regrease everything.
Old Jun 21, 2009 | 12:44 AM
bayou barataria's Avatar
bayou barataria
My '08 brake pads have some kind of clips on them that push the pads away from the rotor when you let off the brake, maybe you could try a set of those if they fit.
Old Jun 21, 2009 | 12:56 AM
ReAX's Avatar
ReAX
The 02 do too. My neighbor's excursion had the spring, but the shop that did the work installed them on top of the leaf springs. He's messed up some rotors and pads, but it hasn't caused a bad caliper yet.
Old Jun 21, 2009 | 08:31 PM
stronger's Avatar
stronger
Huh? the little springs are more like springloaded clips. it's just a clip like any pad clip but with a tab of bent over springsteel that is in theory suppose to bring the pads back away from the rotor. I just did a set yesterday in an '06. like they said, clean everything and get new hardware.
Old Jun 21, 2009 | 08:51 PM
ReAX's Avatar
ReAX
The ones I've had were spring wire bent into a horse shoe shape with the ends bent in. The wire ends inserted into the pads to keep them off the rotor.
bach44
General Automotive Discussion
Jan 26, 2015 12:00 AM
stevorino
Jun 17, 2013 06:34 AM
greenwoodford
Feb 15, 2011 08:16 PM
sflem849
Nov 4, 2010 03:42 PM
2001 7.3
Jan 30, 2010 03:54 PM
