egt temps
Old Jun 19, 2009 | 07:38 AM
Peterbilt376x's Avatar
Peterbilt376x
egt temps
i was wondering what the max egts should be for my 7.3idit. i have my pyrometer right on the exhaust manifolt though not behind the turbo because that was too much of a pain in the *** to do....so i was wondering if the limit is still 1250 or is it higher because its reading it right off the manifold? because right now when i go up a hill and floor it it reaches right around 1250-1300 thanks
-michael
Peterbilt376x
egt temps
-michael
Old Jun 19, 2009 | 09:39 AM
87crewdually's Avatar
87crewdually
-michael
I would stay to the safe side and not let it get above 1200. The piston tops will melt if above 1250 for extended period off time (seconds).
Old Jun 19, 2009 | 12:27 PM
Ironman03R's Avatar
Ironman03R
Before the turbo is best. 1250 is a good limit for sustained running. I have hit 1400 on occasion for short bursts, but I try to keep it around 1250.
Ironman03R's Avatar
Ironman03R
Old Jun 19, 2009 | 08:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What are you running for an exhaust system?
1200 is rather high for more than a minute of so.
Extended pull, stay around 1100 - 1150.
My reason is the piston cooling jets are spraying oil on the bottom of the piston, and that puts a lot of heat into the oil.
olfordsnstone
Aug 10, 2013 08:41 PM
Shanejet
Dec 28, 2012 07:54 PM
dieselsmoker
6.4L Power Stroke Diesel
Apr 16, 2010 09:19 AM
stangman516
Dec 3, 2008 02:28 PM
89toyhauler
Jun 5, 2008 11:01 PM
