Raising (not lowering)
Old Jun 18, 2009 | 06:11 AM
Doraville's Avatar
Doraville
Hello All,
It's been over a year since I posted; sorry for being gone so long!
I'm taking delivery on a '51 F1 today. The truck has had all the hard stuff done to it already; 302 with 3 speed overdrive tranny, Camaro clip, etc. I should be able to post photos later.
My question is related to the ride height of the truck. The Camaro clip resulted in the front being dropped 2-5 inches (I haven't measured it yet). The PO removed 3 helper springs to lower the rear to match the front. The truck drives and looks good, but I prefer the stock stance on these trucks.
I realize that I'm going in the opposite direction of most of the folks in this forum, but does anyone have any advice on the best way to go about raising the truck to more of a factory stance?
Peace,
-Doraville
Old Jun 18, 2009 | 07:38 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you can determine if the coil springs were cut you could go with stock height springs. If they haven't you could go with coils from a big block but it might adversely affect the ride. You might even get an inch or so using coil spring spacers. Also you might get some extra height with larger or higher profile tires. What size tires do you have on there now front and rear? If you are running 60 or 70 series tires you can go with the higher profile 75 series or convert to a larger diameter wheel.
Old Jun 18, 2009 | 07:39 AM
jim collins's Avatar
jim collins
Mount it on a 72 f/100 [115 in frame ] ? that of course is a major job, maybe not what you are looking for ?
Old Jun 18, 2009 | 07:44 AM
AXracer's Avatar
AXracer
put a stock frame and suspension back under it? You're right, seems bassward to pay for all that work then undo it.
Old Jun 18, 2009 | 08:58 AM
56panelford's Avatar
56panelford
Do you know if the camaro suspension is stock or does it have drop spindles on it and possibly drop springs as well. I'd leave as is before I'd go to the expense of trying to convert back to original if it wasn't something simple.
Old Jun 18, 2009 | 10:30 AM
Doraville's Avatar
Doraville
Thanks for the responses guys. I realize that I am in the minority opinion here (not wanting my truck lowered). No disrespect intended for all you guys with lowered trucks. I think lowered trucks look great, it's just that I personally like more of a factory stance.
I should be able to spend some good quality time with the truck this weekend. I'll try to figure out how 'stock' the setup is, and I'll post lots of photos.
Thanks again guys!
-Doraville
Doraville's Avatar
Doraville
Thanks again guys!
-Doraville
Old Jun 18, 2009 | 01:03 PM
56panelford
Thanks again guys!
-Doraville
I don't think your in a minority for wanting a stock looking truck as there is plenty on here and look very good, it just that you might be in for spending a bit more in trying to get back to the hieght you're looking for because of the conversion that has already been made to it. When your check it over check to see if has the stock spindles and not the dropped as that is 2 1/2 inches right off the start.
Old Jun 18, 2009 | 02:35 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I don't think you're nuts for wanting a more traditional ride height. In fact, its kinda refreshing to see a thread that doesn't include air bags or slamming it to the ground and running huge diameter wheels with low profile tires (it won't hurt my feelings when that craze goes away)
As already been stated your best bet is to make sure you don't have dropped spindles and to check to see if the stock camaro springs are chopped. If the springs are chopped then replacing them is fairly easy.
There is a small chance that the whole front clip was set up to be lowered, if thats the case then you are kinda hosed.
I'm running the stock suspension in my 49 with a big Caddy engine. I do have it lowered slightly in the front just because I like a bit of a rake.
Bobby
Old Jun 18, 2009 | 03:27 PM
bobj49f2's Avatar
bobj49f2
I agree with Bobby, it seems like everyone is dropping their trucks and shoeing them with 20" ghetto wagon wheels. I like the stock stance, maybe a little drop. As with any modification, it's your truck and you're using your money and should have the truck the way you want it. I say, be different, and raise it and stand out in the crowd.
Good luck with the de-mod, hopefully it can be done without too much work or expense.
Old Jun 18, 2009 | 08:08 PM
AXracer's Avatar
AXracer
I don't have a problem with you wanting to raise your ride height to stock height, it's just the idea that you were touting the new suspension and all then saying you wanted to raise it back up, diametrically different directions? Raising an IFS above it's original design height after the fact is going to comprimise the geometry, how much depends on how much you raise it and how you do it. The rear springs were originally designed to carry a certain amount of load, not be driven empty all the time. Loading the bed to that design weight would drop the ride height. Most find that without a load the rear is too stiff and hops around a lot over bumps, so they remove some spring leafs. The net results of adding load or softening the springs brings the ride height to a similar level.
Old Jun 18, 2009 | 08:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by AXracer
... Raising an IFS above it's original design height after the fact is going to comprimise the geometry, how much depends on how much you raise it and how you do it. ....
I think the point here is, installing a Camaro sub doesn't in itself necessarily lower the front end. Something else may have been done that made it lower, and may be easily reversible.
Doraville, Can you snap a picture of the subframe where it grafts onto the stock frame? That will be the first clue in what was done to it.
Old Jun 18, 2009 | 10:00 PM
B/B ford's Avatar
B/B ford
Clean & Classy
I have never seen a Camaro swap done that did not intentionally lower the front end of a truck.(I know that doesn't mean it hasn't been done).
Now how about a little shoe on the other foot, and leave this nice darksided truck alone and go find some stocker to build.
(he said with tongue in cheek)
Old Jun 19, 2009 | 07:11 AM
bobbytnm's Avatar
bobbytnm
Now THAT cracks me up!
LOL
Bobby
Old Jun 19, 2009 | 09:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I have to say, the concept of doing a Camaro subframe with a Ford 302 eludes me. Maybe hook it all up to a 727 trans with a Studebaker rear axle, Toyota PS?
