no running lights
Old Jun 17, 2009 | 01:47 PM
limeyellowfellow's Avatar
limeyellowfellow
no running lights
Hi all, I have an 86 F-350 with a Banks on a 6.9. When I purchased this truck all the running lights and instrument cluster lights worked except the driver's front. Now none work, including the instrument cluster lights. The guages and tach work. I have checked the fuses (none blown) and replaced all the bulbs without success.
I am at a loss as to the problem. Does anyone have any suggestions? Thanks. - John
Old Jun 17, 2009 | 05:15 PM
dustybumpers's Avatar
dustybumpers
headlight switch is probably bad. could also be the wireing harness where it plugs on to the headlight switch. you have to remove the switch, and seperate the 2. usually they get hot, and melt the plug. could also check for bad wire job on trailer hookup, might be shorting out the running lights
Old Jun 17, 2009 | 05:40 PM
limeyellowfellow
Dustybumpers. Thanks for the reply. I have put a new headlight switch on and I removed the trailer lights as the previous owner did a crappy job of installing them and the splices were grounding out on the hitch receiver.
Old Jun 17, 2009 | 05:42 PM
dustybumpers
are you still haveing a problem, or did you fix it? if still a problem, check that the wires are pushed in on the plug to make a good connection
Old Jun 17, 2009 | 06:18 PM
hp246's Avatar
hp246
Does it have the floor mounted dimmer switch? If so, try a new dimmer switch.
Old Jun 17, 2009 | 06:50 PM
Franklin2's Avatar
Franklin2
Dimmer switch goes to the headlights only. If he didn't get it fixed, more than likely the tan/white wire going to the headlight switch is burned in two.
Old Jun 17, 2009 | 10:04 PM
limeyellowfellow
Hey guys, no I haven't fixed it yet. The dimmer switch works. I will look at the brown/white wire. Thanks for the suggestions. I'll let you know what happens.
-John
Old Jun 21, 2009 | 11:15 AM
limeyellowfellow
Franklin2,
Thank you for the advice. The tan/white wire was the culprit. I had to replace a bunch of wires coming from the fuse block last year as the previous owner only used 30 amp fuses and melted a bunch of the wiring. I didn't have the new tan/white wire pushed far enough into the fuse block to get power. It was a 5 minute fix. THANK YOU! This is a great site! Thank you to everyone else who gave me pointers as well.
Old Jun 21, 2009 | 04:16 PM
dustybumpers
cool deal. glad it worked out for you
FordFinatic157
Oct 5, 2013 09:35 PM
concept304
1983 - 2012 Ranger & B-Series
Mar 5, 2012 10:47 PM
I_Thnk_Ford
Jan 5, 2005 07:46 AM
Kevin
Jan 4, 2000 12:19 PM
