Squeak under front
Old Jun 16, 2009 | 10:25 AM
97-7.3's Avatar
97-7.3
Squeak under front
I have a squeake every time I run over a hump, or tork the frame by turning in or out the driveway. Truck is a 97 f250HD 4x4 four door short bed.
It sounds like the front shocks top mount is rubbing the shock bushings. Anyone have this noise and what can ya do?
Old Jun 16, 2009 | 11:20 AM
Talyn's Avatar
Talyn
check the spring bushings for the leafs. they go bad.
Old Jun 16, 2009 | 11:32 AM
Hussler's Avatar
Hussler
Common problem on these rigs. Try tightening the side fender bolts (two) on each side as shown below. They might be snug but wrench down on them real good.
Old Jun 16, 2009 | 12:11 PM
Talyn's Avatar
Talyn
Yea, mine didn't squeek, but I still tightened them as well.
Old Jun 16, 2009 | 12:25 PM
97-7.3's Avatar
97-7.3
Thanks .. it sounds more like a lite gauge metal squeak, more like the fender than spring bushings. I did notice when changing the front shocks that they do not line up exactly and are at a slight angke to the top shock bracket.
I will tighten the fender bolts and if it doesn't stop, lithium grease the sides of the shock bracket.
Old Jun 16, 2009 | 12:35 PM
Neal 97 250's Avatar
Neal 97 250
X2 on the fender bolts.
VERY common problem.
Old Jun 16, 2009 | 12:38 PM
Neal 97 250
One more common problem I had when mine was new. Loosen the skid plate bolts under the TC and put a rubber shim or piece of floor mat in there. It made a loud POP on mine.
The dealer fixed mine back in '97 with a piece of floor mat.
Old Jun 16, 2009 | 01:02 PM
97-7.3's Avatar
97-7.3
My squeak / scrunching is loud and sounds like light gauge metal ... I just don't believe it's the spring bushings, the squeak sounds much more hollow than that.
Old Jun 16, 2009 | 01:07 PM
Neal 97 250
It most likely will be the fender bolts. If it continues after tightening then put a rubber shim in there to see it that helps.
Old Jun 16, 2009 | 01:09 PM
97-7.3's Avatar
97-7.3
Will do ... thanks for all the replys.
Old Jun 16, 2009 | 01:45 PM
Neal 97 250
Mine rubs under the bolt head. The head/washer rubs on the fender itself
Old Jun 16, 2009 | 07:35 PM
pjwoolw's Avatar
pjwoolw
Squeak and Pop
Here is another possible cause. Mine is really bad after new springs and bushings.
970310.pdf
File is to big to display. It should download to your machine. I think.
dmfireaxe
General Diesel Discussion
Sep 8, 2009 08:20 AM
goatdriver
2004 - 2008 F150
Jun 3, 2007 07:47 PM
wat704
1997 - 2003 F150
May 1, 2005 11:45 PM
Ron_Hanson
Jul 21, 2003 07:51 AM
mikeB1
1997 - 2003 F150
Oct 27, 2002 02:08 PM
