Squeak in front drivers side wheel area
Old Jul 17, 2003 | 12:06 PM
Ron_Hanson's Avatar
Ron_Hanson
97' eddie Bauer 118K 5.4 4x4
I have a really annoying squeak in the front drivers side wheel area, it will still squeak at any speed but I've notice that it will not do it near as bad when I am turning to the left, I have checked the brakes and they seem to be in good shape. Also the squeak will not change when I brake so I am pretty sure that it is not the brakes anyway. Any info on this would be well appreciated.
Dave
Old Jul 17, 2003 | 01:02 PM
white99's Avatar
white99
We had the same problem. Unfortunately our normally excellent ford service dept told us it was brake dust.Even did a front brake job for us and it did not go away. Turned out the local tire shop repacked and tightened the bearing and it has been gone for almost a year now.
JimP
Old Jul 18, 2003 | 03:21 PM
Ron_Hanson's Avatar
Ron_Hanson
That could be it, does anyone else have any other ideas on what it could be?
Old Jul 19, 2003 | 09:51 PM
Gearhead2's Avatar
Gearhead2
Check your front air shock for a leak. (That is, if you have the load leveling air shocks). Try bouncing the front end by slowly driving and then pumping on the brakes--listen if the squeak mimics the bounce.
Old Jul 19, 2003 | 10:37 PM
BigMattXXL's Avatar
BigMattXXL
Lightbulb Squeak in front drivers side wheel area
Try this - take off your center cap on the wheel. Underneath, you'll see a dust cap covering the axle nut, and it's held on by a cotter pin. I've found that the dust cap tends to make a squeaking noise. Tap it/shake it and see if you can recreate the noise. I pull the cotter pin out, line the inside of the dust cap with RTV silicon, stick it back, put the pin back and voila, squeak's gone.
Hope this helps!
XXL
Old Jul 20, 2003 | 01:41 PM
tsdrallyer's Avatar
tsdrallyer
I've had a few vehicles in the past with plastic hub caps that squeaked. Take off the hubcap of the wheel and see if it makes a difference. If may stop it, or make it louder. If louder, then maybe it was in the hub cover scraping the cotter pin.
Although you may have greased the regular places where there are zerks, try injecting with a needle fitting on the grease gun, a half teaspoon of grease into each rubber joint cover on tie rods, pittman, etc. . This stopped the only squeak I've ever had with my Expy. Hope this helps.
Old Jul 21, 2003 | 07:51 AM
ExpyBoy's Avatar
ExpyBoy
On my poor tank... the squeek was associated with the suspension travel... I crawled under it while my wife jumped up and down on the front bumber... I traced it to the rear Bushing for the lower A Arm. I I packed some grease onto the threads and applied some Syl-Glide to the rest... It went away after a few days... (That is until I beat it off-road again)
Big Grey
Oct 24, 2012 11:59 PM
onekickjim
1997 - 2003 F150
Jan 11, 2009 04:19 PM
kgenik
1997 - 2003 F150
May 19, 2008 08:42 PM
naiku
May 23, 2006 12:20 PM
highboy390fe
1997 - 2003 F150
18
Mar 29, 2006 09:45 AM
