Offroad & 4x4
tire width VS. rim width
Old Jun 14, 2009 | 11:15 PM
oldirtytruck's Avatar
oldirtytruck
I asked this in the wheel forum but no one has answered.
I would like to place larger rims and tires on my truck but I'm puzzled... in the old days you had a choice of 15 and 16 inch rims and they were between 10 or 12 inches in width.
Now days it seems like all rims are only 9 inch in width. Will a tire (38inch tall by) 13 to 15.50 inch wide fit on a rim that is only 9 inches in width? Im shooting for a 20 inch rim but the styles I like are only 20,18,17 x9.
Old Jun 15, 2009 | 02:15 AM
rebocardo's Avatar
rebocardo
Because most newer vehicles can't take wider and taller tires without serious work and the rims are for plus sizing (rubber band tires) and not for adding wide traction tires.
Yes, but, for tires 33> and up you really should stick to the 4" rule. Basically any tire is good to go as long as it is 1-4 inches wider then the rim. So, for a 9" rim, 13" is the most you want to go width wise. Especially if you go BIAS.
Doesn't Tyres Int. have rims in the style you want?
Old Jun 16, 2009 | 10:10 AM
hav24wheel's Avatar
hav24wheel
It all depends on the sidewall hieght. Personally I would look at what the tire manufacturer recommends for that tire size. If you use too narrow of a wheel it will pull the sidewalls in too much, making the tire look stuid and have abnormal wear. Also too wide the sidewalls will be pushed out too much, and it will be easiier to pop off the bead.
Old Jun 16, 2009 | 09:45 PM
Stickz's Avatar
Stickz
Are you using these on or off road? As suggested above, check with the tire manufacturer to see what they recommend. If you use is manly off road then you can go with a rim that is a little narrow then they recommend.
For a 13.5" wide tire, I wouldn't go less then a 10" rim and for a 15.5" wide tire, I'd go with a 12" wide rim.
Old Jun 17, 2009 | 08:15 AM
oldirtytruck
It's my DD do it would be about 90 on road.
Old Jun 17, 2009 | 11:29 AM
Stickz's Avatar
Stickz
For a DD that is mainly on road, go with a wider rim for better tire wear.
See what the tire manufacturer recommends and if there is a range in the width go with the wider one.
Old Jun 17, 2009 | 09:02 PM
oldirtytruck
Ok thanks for all the help.
Old Jun 20, 2009 | 08:02 AM
Mud Rat's Avatar
Mud Rat
National Tire and Wheel Online can get you almost any rim for any tire.
Old Jun 20, 2009 | 02:20 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
wheel needs to be the same as the section width of the tire, preferably wider
Old Jun 22, 2009 | 03:46 AM
Furian's Avatar
Furian
You Keep What You Kill
I have a set of five 18X10 Gear Alloy 712C's for sale. They have 4.5" of back spacing and are brand new in the box.
Old Sep 20, 2010 | 09:03 PM
PAINTERDAVE's Avatar
PAINTERDAVE
Are these still for sale?
Old Sep 20, 2010 | 09:21 PM
Furian's Avatar
Furian
Yeap! They haven't been moved for over a year... send me a PM if you are interested.
Old Sep 21, 2010 | 09:34 PM
PAINTERDAVE
I'm new to this forum and have not figured out how to pm yet. But if you will send me an email (DLR1000@rocketmail.com) or give me a call (336)813-5347 I'll see if I can get these things out of your garage for you. Thanks, David
Old Sep 21, 2010 | 10:04 PM
Furian's Avatar
Furian
I sent you an email.
noimports
Feb 17, 2017 09:27 PM
chrislynn5
32
Sep 10, 2016 11:51 AM
SSSimon
Australia Chapter
30
Feb 17, 2016 03:18 PM
Jus2shy
2009 - 2014 F150
May 5, 2013 10:14 PM
Dad's Ride '11 F-250
Jul 1, 2012 12:26 PM
