I have a 2011 F-250 Crew Cab Lariat Shortbed and I'm looking to go from factory 20" rims with 275/65R20 tires to 18x9 RBP wheels wit 325/60-18 BFG's. I don't want the new wheels to stick out too far. I like the tucked under look to fill the fender well. Does anyone know how much offset I should use and if these would rub. The overall diameter is only 2 tenths of an inch difference. I'm not planning on adding a leveling kit. I realize the width is a little wider with the 325's but hope they will work okay. Any input would be greatly appreciated. What happened to the days when you could just go buy some 15x10's and throw some 33x12.50's on there and let it ride?
unfortunately things are a little tougher now but if you guys have any suggestions that will help I'd be grateful. Or anyone that has changed their tire and wheel size, let me know what offset worked for you and how it looked with the aftermarket wheels.
Are those 18x10's or 18x9's? What offset did you get? Actually I think yours looks really good. I Don't mind an inch or so hanging out as long as theres plenty of tire under the fenderwell. Some flares would look really good with that also. Thanks for the pics!
