Will these tires rub? 295/60r20
I want to run these tires on the stock rims with no lift or leveling if they will work. I like the size because it is a little wider and aggressive looking without changing the stock height. This way my speedo should still work and im not changing anything except the tire width. These are the Nitto Terra Grapplers G2. Load rating is 3750. They would replace the Michelins 275/65r20. Toyo AT2's and Cooper Discover AT3 are also offered in this size. Basically they are 34 x 11.8 inches.
I have the TOYO AT II 295/65R20 with stock wheels and no rubbing. That's why I went with that size because everyone was saying it will work on stock truck (no lift, no level). I'm running 60 psi all around. I had originally put 65psi in the rear when I put the tires and it was too much. Also I'm only 1 mph off at 70 mph on GPS and dash showing 69 mph. I'm good with that. Another note is a 295/65R20 is the largest tire you can put on a 8.5" wheel and stay in spec of the tire. If you have 20" wheel it is a 8.5" width.
xbrxlunch
11-28-2012 02:41 AM
