Automatic Trans Cooler
Old Jun 14, 2009 | 10:33 AM
dantsg's Avatar
dantsg
I have a 98 F150 5.4 4x4 XLT and want to put a trans cooler in. I see a small two row cooler in the front of the truck (looks factory) and if that is the cooler it looks like it is too small for any real load. Is this the cooler and is it effective?
Old Jun 15, 2009 | 02:18 AM
rebocardo's Avatar
rebocardo
Somewhat. In Dodge and Fords, your radiator cools it too. But, it is not uncommon to have your truck overheat and blow the transmission at the same time. That is why an external cooler with fan that totally by-passes the radiator is recommended.
Old Jun 15, 2009 | 05:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's not recommended by everyone. I don't think it is a good idea.
The radiator cooler is MUCH more effective at cooling the trans at low speeds. If you do a lot of backing or city driving I would leave the radiator cooler installed.
Old Jun 15, 2009 | 07:38 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I personally don't know, I don't do Autos for _my_ vehicles, my wife does, but they are kept stock. I personally don't like them.
Though I have been told to run it through the radiator cooler then through a transmission cooler, and anything you can do to increase the oil capacity the better.
Is that sound advice Mark?
-Enjoy
fh : )_~
Old Jun 15, 2009 | 09:28 AM
Lazy K's Avatar
Lazy K
Originally Posted by dantsg
I have a 98 F150 5.4 4x4 XLT and want to put a trans cooler in. I see a small two row cooler in the front of the truck (looks factory) and if that is the cooler it looks like it is too small for any real load. Is this the cooler and is it effective?:confused:
Follow the lines back, if you can. If they go to the engine oil filter then it is an engine oil cooler if they run on back past the engine then it is for the trans.. If it is the trans cooler then you could just plumb in a bigger one.
Old Jun 15, 2009 | 09:47 PM
Mark Kovalsky
I agree with your flow path. I don't see what additional fluid does for the trans.
Old Jun 15, 2009 | 09:59 PM
Festus Hagen
Methanoholic
Thanks Mark
-Enjoy
fh : )_~
4byford
Mar 14, 2017 08:01 AM
jimbo1969
Jul 29, 2016 01:54 AM
parcours
2009 - 2014 F150
Dec 6, 2015 11:44 AM
Leichardti
Feb 15, 2013 04:42 PM
khmorse
Jan 26, 2003 06:47 AM
