Trans cooler line direction and oil pressure sender location? 93' F350 7.5
1993 F350 7.5 4x4
Original owner plugged trans cooler on radiator and ran a small external front mount cooler. I just added a larger trans cooler and new radiator.
Which line is In and Out on the trans?
Is the proper order: Out trans> top of radiator >bottom of radiator > top trans cooler > bottom of trans cooler> back to trans. ?
Adding new gauges as well.
Where is the oil pressure sending unit? Going to remove and run gauge from there.
The coolant temp sensor is the one next to the thermostat housing, correct?
Thank you for your time.
The oil pressure sending unit is behind the manifold, directly in center of the engine block.
Attachment 293566
Attachment 293566
lud04X
08-15-2016 09:21 AM
skywagon
03-23-2004 11:34 AM
barthur
05-17-2001 04:23 PM
cbremer
04-10-2000 09:40 PM
