What up with this?
Old Jul 5, 2009 | 05:26 PM
  #31
74baja's Avatar
74baja
I have a question. What exactly does a contribution test measure?
Old Jul 15, 2009 | 04:46 PM
  #32
fifthwheel01's Avatar
fifthwheel01
the stealerships payroll fund.
Old Jul 15, 2009 | 04:56 PM
  #33
superduty4x4's Avatar
superduty4x4
I don't have a technical explanation, but basically its a test to make sure that each cylinder is contributing equally to the running of the engine. If one cylinder is really high or really low, it indicates a problem on that cylinder.
Old Jul 15, 2009 | 06:56 PM
  #34
Kwikkordead's Avatar
Kwikkordead
I'll explain this in a little more detail.
The cylinder contribution test is a measurement of each cylinders contribution to the running of the engine.
It measures the amount in percentage of rpm drop per cylinder per ignition event.
If all eight are pulling thier weight evenly you will have zero % on each cylinder.
If you have an injector that is going south then will have a percentage reading for that cylinder.
You can start to feel anything above 5% or so.
It starts to rock the engine at around 15%.
I don't know what percentage a dead miss will be, but the momentum of the flywheel will prevent a reading of 100%, but I hope this explanation helps.
Old Jul 16, 2009 | 12:33 AM
  #35
Visseroth's Avatar
Visseroth
Thank you, this is good information. I didn't know what it was so I thought it to be a good question as well.
Old Jul 16, 2009 | 04:41 PM
  #36
MSB6's Avatar
MSB6
What are the symptoms if an injector is starting to go bad? It seems to run good on the highway above 1500 rpm but below that in stop and go traffic, mainly at lower rpms, it feels like a miss. My fuel mileage has dropped 3-4 mpg and it has started using some oil. Approx 3 qts per 5000 miles.
Old Jul 17, 2009 | 08:48 PM
  #37
74baja's Avatar
74baja
Awesome explanation Dan! I totally get it now. So, if one cylinder is not producing as much HP as the average of the others, it will actually slow the engine down, so they can measure the RPM at each ignition to find which cylinder is slowing things down. Cool. I guess it would be good to do this in conjunction with a compression test to make sure that things aren't just weak all around, or to help diagnose why the contribution is off.
Old Jul 17, 2009 | 11:59 PM
  #38
Kwikkordead
That's it right there.
BluePitt
Dec 31, 2011 09:40 PM
DieselBeast01
Jul 11, 2009 08:45 AM
kalsc
Sep 27, 2006 09:21 AM
anthony99
35
Dec 20, 2004 06:10 PM
Shadow Hills Super Duty
Dec 22, 2003 07:55 PM
