My luck!!
Old Jun 10, 2009 | 10:06 PM
c00nhunterjoe's Avatar
c00nhunterjoe
5k would work but what kind of resistor is it? i havnt seen the 1/4 watt resistors in 5k, just 4.7k.
Old Jun 10, 2009 | 10:10 PM
97biostroke's Avatar
97biostroke
Jethro- you can hit 27 lbs of boost on stock injectors? I have the same mods you do but i dont have gauges to monitor with
Old Jun 10, 2009 | 10:11 PM
c00nhunterjoe
i am lucky to touch 20 psi right before a shift
Old Jun 10, 2009 | 10:20 PM
JethroF250's Avatar
JethroF250
thats like mega WOT i have seen it a few times but lately numbers have been decreasing. the 94.5 to 95.5 7.3's were diff than the 96 and on models as far as fuel delivery etc. therefore causing a slight diff in performance. example5 (my year) runs rougher than lets say a 96 of the same body style. i could go on so my rambling will stop here. but yes i have seen 27 more than once
Old Jun 10, 2009 | 10:39 PM
97biostroke
I knew the 94.5-95 models had slightly different tuning but I thought they were de-tuned compared to the 96-97's. I thought they were tuned for less horsepower (215 instead of 225) but I could be wrong.
Old Jun 10, 2009 | 10:42 PM
73pwrstrk's Avatar
73pwrstrk
idk wat watt it is. i just have it from a circuit kit i had to buy for an E&E college course. is there a way to tell wat the watt is?
Old Jun 10, 2009 | 11:12 PM
c00nhunterjoe
best bet is to buy a pack, the ones from radioshack are 1.99 for 5
Old Jun 10, 2009 | 11:52 PM
73pwrstrk's Avatar
73pwrstrk
alright thanks joe.
hey jethro all i have is intake, 3in dp to 4in straight and 10k mod i can hit 21 to 22 all day. i guess every truck just runs a little different.
Old Jun 11, 2009 | 05:26 AM
JethroF250's Avatar
JethroF250
yep i hear you there. aint no two that are the same
Old Jun 11, 2009 | 07:34 AM
Brown Falcon's Avatar
Brown Falcon
Originally Posted by 73pwrstrk
alright man i wish i could think of all my ?s at once, but is 4k as high as i should go cause i have a 5k would that work ok?
Most guys on here do a 4.7k on the oil temp
Old Jun 11, 2009 | 12:33 PM
73pwrstrk's Avatar
73pwrstrk
does this have to be wired in or can i just bend the ends and put it in the 2 slots and plug it back in?
Old Jun 11, 2009 | 01:13 PM
Brown Falcon
the best way I've seen is to wire a female connector on one end of the resistor and a male end on the other. That way if you want to take it out you just plug the two ends on the wire together
Old Jun 12, 2009 | 01:34 AM
  #28
73pwrstrk's Avatar
73pwrstrk
thats wat i was thinking would be best just figured id see wat you guys though. had to deal with rain all day today so hopefully its nice out tomorrow.
fordboy67
Jun 19, 2014 08:29 PM
SteveBricks
S. California Chapter
144
Feb 28, 2013 09:46 PM
togobefastguy
13
Oct 24, 2012 09:23 AM
patriots6800
Jan 6, 2010 04:37 AM
Aftrmidnite
Aerostar
21
Sep 23, 2004 09:56 PM
